help! Speed sensitive steering issue on my g
Old Oct 14, 2009 | 11:42 PM
rockraines's Avatar
rockraines
Hey folks, new to the forum.
I have a black 09 g37x coupe and have had several issues with the car so far including the transmission reflash issue as well as the alignment slipping out constantly.
The newest problem has me perplexed. My speed sensitive steering seems to have a mind of its own. Sometimes its stiff, sometimes loose and all at the same speed on the same road. It doesnt seem to adjust to speed, it just adjusts when it feels like it. I can be going 80mph on the highway and my steering feels like an Accord, then 15 seconds later it tightens up and lets me feel the road. It does the same thing when traveling at 25mph. Anyone have or heard of this issue??
Old Oct 15, 2009 | 02:45 PM
swordsman54's Avatar
swordsman54
Just to point out, the Accord has speed sensitive steering as well
Old Apr 26, 2012 | 01:09 PM
kayno's Avatar
kayno
I just started having a similar problem.. Only that it doesn't seem to tighten up at all... I'm at the dealership right now and they tell me it's riding fine.. I'm like yes it rides fine if it was a civic.. Not for a g37s coupe.. I can't make fast turns at high speeds without feeling like I might loose control of the car..
Old Apr 26, 2012 | 01:24 PM
Rad_Slinger's Avatar
Rad_Slinger
Ummm. You should probably take it in immediately to have it looked at. It's not some noise you can't figure out, it's steering and if something goes wrong, you're screwed.
But before you do, check the power steering fluid level. Why it would be low I have no idea, but it's worth a shot. If low, top it off...if not, then take it in immediately.
****edit**** ok, well....you're at the stealership already....don't mind me, nothing to see here.
Old Apr 26, 2012 | 01:27 PM
kayno's Avatar
kayno
Yes I am.. And they claim nothing is wrong with it.. I'm trying to let me drive a different car and feel it out
redlinernyc
Feb 29, 2016 11:06 PM
Ricio1991
Sep 8, 2015 09:43 AM
TVPostSound
General Tech Questions
Sep 2, 2015 04:09 PM
