Help Please help me to remove HID ballast.
Old Sep 7, 2017 | 09:39 AM
viclauyyc's Avatar
viclauyyc
I need to replace the OEM HID for a high power LED. I managed to get a set of D2S mount LED for the headlight. But the LED need a regular 12V to power on.
So far, the best way I could think of is, remove bumper > remove headlight housing >remove the ballast> cut off the input wire to get 12V for headlight.
Is there a better way to do it? Like direct wiring to the LED headlight to power terminal? If there is the case, 1 problem, there are 2 terminals for each side of headlight, high and low beam, total 4 plus negative.
what you think?
thanks ahead
Vic
Old Sep 10, 2017 | 05:39 PM
Surfnazi's Avatar
Surfnazi
That's easiest way that way your not fighting for room going through the tire well
