1 Headlight turning off after 10 seconds
Hey guys I am in need of some help here. Just recently I have been having issues with my 2012 G37 sedan.
Back story- Driver side headlight would flicker but then eventually turn on... sometimes it would stay on, sometimes it would turn off... I was told to replace my ballast- which I did.
Once the ballast was installed, headlight seemed to work, a couple weeks went by and I started to notice that the headlight would turn on normally, however, in exactly 10 seconds, it would turn back off... I am at a loss at this point and would appreciate any help here.
1 last thing- when installing the ballast, although I got the part number from the dealership through my vin number, the actual assembly was not the same one as the one that originally came on the car. I was able to move a few things around and got it to work (its an Infiniti OEM ballast, I assume it came on a different model) There was a delay in igniting the driver side headlight than my passenger side... I didn't think much of it, just wanted to make sure it worked...
Please let me know if anyone has ever had this weird issue before. I would also appreciate it if someone can post a picture of a used OEM headlight bulb, that way I can compare it to mine...
Customer satisfaction survey's are very important to dealers.
Trying to save a little money on these vehicles very often leads to frustration and extra expense.
Learned this lesson many years ago.
Telcoman
this statement would be true only if you are talking about filament type bulbs. hid or xenon bulbs arc an electrical current over electrodes. the electrodes do not touch and high voltage electricity arcs over the 2 points. if the electrode is bad or if there is high resistance it can affect bulb performance or operation.
can anyone point me to the right direction as to where I can find the OEM bulbs for this car?
Also, if the ballast was not the same exact ballast (although, still a infiniti ballast with the same attributes) could this issue occur?
The (different) ballast shouldnt matter. Im running different ballasts in my car. Im having the exact same issue you are, and in my case its the bulb. It will light briefly then after a minute it dies. Ive tried multiple ballasts and same results. Switiching the bulb clears the issue....
