how to reset engine service soon light
Old Jul 23, 2017 | 06:56 AM
billtallard's Avatar
billtallard
2013 G37 ipl convertible
Old Jul 23, 2017 | 11:24 AM
Take a look at this, and if that won't do it, a battery disconnect will work. Also you can go to an auto parts store and use their code readers that will reset your ECU. Keep in mind if you do the battery disconnect you'll have to reset your memory seat settings, etc.
https://www.myg37.com/forums/d-i-y-i...isconnect.html
Old Jul 23, 2017 | 02:11 PM
SkyG37's Avatar
SkyG37
I follow this video as he does it. So when he turns on the ECU, so do I.
Old Jul 23, 2017 | 03:56 PM
Melophile's Avatar
Melophile
If you reset the CEL without solving the issue that's causing it, then the CEL will just reappear.
I have a wifi OBD2 scanner from Amazon and Dash Command from Apple's App Store. That's what I use for diagnostics and clearing codes.
Old Jul 24, 2017 | 09:23 AM
JustROLLIN's Avatar
JustROLLIN
This.
I have a bluetooth scanner that I bought for around $10 and the Torque app for Android which was another $10 I believe. So for $20 I can clear codes, log, etc. Its a pretty solid return for only $20.
babskyline
Intake and Exhaust
Jul 3, 2019 02:41 PM
Jen37S
May 14, 2017 02:43 PM
avol3xo
May 2, 2017 06:37 PM
g35aa
May 1, 2017 01:15 PM
