Rust Bubbles on the roof...
Old Jul 12, 2016 | 04:30 PM
G37X GraSdadow's Avatar
G37X GraSdadow
Found a small area of bubbles on top of the roof. I am 90% positive these are rust bubbles.
Should I get it repainted?.. or just leave it alone..........................
The bubble area is size of a nickle or penny.. maybe little smaller.
I can't believe I noticed this now.
So many issues this month..
Old Jul 12, 2016 | 04:46 PM
Baadnewsburr's Avatar
Baadnewsburr
In my experience bubbles that appear in paint/rust bubble indicates corrosion from the inside of the panel working its way out. If you can its best to stop them from spreading as its the kind that will eat away at the car. That being said, in practice, I tend to let body panel corrosion like that get worse before I do anything about it because its usually already a lot worse under the surface already and the entire panel will need to be refinished...its not a matter of overlaying some filler/touch up paint...if you don't get all the rust it will just come back
Old Jul 12, 2016 | 11:32 PM
dkmura's Avatar
dkmura
20 Year Member
Why not take it to your local Infiniti dealer for an inspection? Take a closer look at the damage and use your body warranty if corrosion was the cause.
Old Jul 12, 2016 | 11:51 PM
Ummm, he's in a current "situation" w/ his local dealer, but maybe another within a reasonable drive perhaps?
Old Jul 13, 2016 | 03:23 PM
Epiphany's Avatar
Epiphany
Got a pic of it?
Old Jul 13, 2016 | 04:45 PM
SonicVQ's Avatar
SonicVQ
The warranty is for "perforation" and since there is no hole, they won't do anything. I suspect it is a stone chip exposed the base metal and it is rusting under the paint.
If you do nothing, it will continue to grow wider and deeper. If you plan on keeping the car wither fix it yourself or pay someone to fix it.
Old Jul 13, 2016 | 05:25 PM
G37X GraSdadow
I took it to other infiniti dealer.
The inspector told me the 'basic' corrosion warranty is 4 years.
However I have CPO Elite extended warranty. Not sure that would do anything about this.
The inspector inspected the bubble, did not see any rock-chipped so he took some pictures and information so he can send them to Infiniti.
He told me wait at least 48 hours to get the decision from Infiniti.
Let's see how they will handle it.
Old Jul 20, 2016 | 03:56 PM
G37X GraSdadow
The manager who called the infiniti went out for vacation. The other associates told me that I have to wait until he comes back.. (what?)
Anyways, this is the exactly what I have on my roof. Probably a bit smaller.
Old Jul 20, 2016 | 03:57 PM
G37X GraSdadow
http://www.diy-car-painting.com/images/RustBubble.jpg
Old Jul 25, 2016 | 05:26 AM
rj8dan's Avatar
rj8dan
Keep us posted. If you're going to fix it by yourself, sand the affected area, apply rust converter, primer then paint.
Old Jul 25, 2016 | 03:42 PM
G37X GraSdadow
Updated 7/25/2016.
Infiniti Service Manager called me today.
Told me that it is not the corrosion damage but it seemed to be an issue with clearcoat and the paint. Manager however did get an approval from infiniti to fix my roof! which is awesome!!! I definitely like this dealership better than the other one.
Old Jan 17, 2018 | 05:55 PM
devil2k's Avatar
devil2k
Right above the driver side A-pillar.
Just noticed a similar problem on my 2010 G37x Sedan. It's not a rock chip.
I bought the car new in Oct 2010 and the trunk had rust perforating from the inside, too, within 2 months of delivery. That was taken care of by the warranty.
Old Jan 17, 2018 | 08:32 PM
saywat?'s Avatar
saywat?
im gonna assume under the black trims ull see more action
Old Jan 18, 2018 | 09:43 AM
NealP's Avatar
NealP
Originally Posted by G37X GraSdadow
Updated 7/25/2016.
Glad they were able to take care of you and you found a good dealership!
Old Jan 18, 2018 | 09:57 AM
jfridge92's Avatar
jfridge92
I went and looked, and my '13 Journey Sedan has a rust spot in this exact same location that also doesn't look like a rock chip. I wonder what the odds of the dealer warrantying it would be, considering other spots on my car unfortunately do have rock chips?
G37X GraSdadow
Aug 19, 2016 09:10 AM
ericxd
Jul 15, 2016 04:15 PM
scaperd
Jul 11, 2016 06:29 PM
j50ny
Jul 6, 2016 02:27 PM
