Help What winter tire size for 2010+ G37xS Sedan?
Old Jul 10, 2016 | 04:15 AM
ericxd's Avatar
ericxd
What sizes will work for the the 2010+ G37xs sedan? (My stock size is 255/50/18 all around)
I have a extra set of 224/40/18 and 245/40/18, does that work?
Old Jul 10, 2016 | 11:57 AM
You should have 225/50, not 255/50 as your stock size.
You need to run all 4 the same or ones that are less than 1% different in diameter front to back. The 225/40 is over 7% smaller than OEM and the 245/40 is over 4%. The difference front to back w/ those new tires you listed is almost 2.5% different.
All those combos are bad. For a winter tire you want narrow for best snow duty, I'd stick w/ 225/50/18s.
Old Jul 15, 2016 | 04:15 PM
Neal@tirerack's Avatar
Neal@tirerack
MYG37.COM Platinum Sponsor
Narrower tires cut through ice/snow better than the wider ones do. Most functional size with the correct outside diameter would be 225/50-18.
Mattlorentzoe
Dec 26, 2020 06:03 PM
bkkellz
May 2, 2016 09:39 PM
Mikekg37x
Apr 28, 2016 10:41 PM
tristan615
Apr 25, 2016 11:15 PM
