Help 2012 coupe door sill removal
Old May 8, 2016 | 09:55 AM
OfficialG's Avatar
OfficialG
I am going to be vinyl wrapping all the time inside my '12 coupe including my door sills so I'd like to remove them. I have seen two different types of sills on the G37 (all diff years) and was wondering if the 2012 coupes had their sills held on by double sided tape or clips? thanks.
Old May 8, 2016 | 12:17 PM
ILM-NC G37S's Avatar
ILM-NC G37S
If I recall correctly only the illuminated kick plates use double sided tape while the standard kick plates use clips. I used a narrow putty knife covered in electrical tape (ghetto but worked perfectly) and pried them off when I installed the illuminated plates. They're real easy to remove either way.
Old May 8, 2016 | 12:32 PM
OfficialG's Avatar
OfficialG
Ok thanks..yea I have the illuminated one and wanted to know if I should buy some mounting tape or not. thanks!
Old Aug 17, 2016 | 11:03 PM
sho423's Avatar
sho423
How do you get the door sills out? Am I suppose to take out the black cover next to it or does the door sill just pop off?
Old Aug 18, 2016 | 08:56 AM
2008G-Man's Avatar
2008G-Man
3M makes the mounting tape and you can get it at Lowes/Home Depot and probably most auto parts stores. Hardest part will be getting the old ones off without bending and damaging them. I would wrap around them if it were me.
Anotherreject
General Tech Questions
Nov 18, 2016 12:52 PM
Thunder18
Apr 14, 2016 10:31 PM
g37socal
Apr 13, 2016 11:19 PM
TrunkSlamchest
Apr 9, 2016 05:56 PM
