Restored and Tinted My Tail Lights Today
Old May 6, 2016 | 12:20 AM
Thirty_Seven's Avatar
Thirty_Seven
Originally Posted by saywat?
nice wat'd u use to clear it?
Duplicolor Automotive Grade Clear Coat. It was cheap and wetsandable so I went for it. Found it at autozone.
Old Jul 24, 2016 | 03:59 AM
Braze's Avatar
Braze
Talking Tint
the previous owner may tint it by himself.hahahahahaah
I recommend http://www.tintingtool.com/ to you if you want to tint by yourself.
Old Jul 24, 2016 | 04:00 AM
Braze's Avatar
Braze
Talking Tint
Old Jul 24, 2016 | 04:05 AM
Braze's Avatar
Braze
the previous owner may tint it by himself,hahahahaahah
Old Jul 28, 2016 | 02:24 PM
Mattyem's Avatar
Mattyem
Originally Posted by Thirty_Seven
So the previous owner of my car tinted the tail lights at some point and did a horrible job. I don't think he cleared them at all and after a couple passes of compounding and polishing, the tint was gone and there was absolutely no UV protection.
The lights started showing signs of wear and there were a million little "cracks" and they looked very faded and always drove me nuts. Today I sanded them down and tinted them, and I think they came out pretty good.
Here's my process in case anyone is interested:
1. Clean the tails with 1:1 mix of rubbing alcohol and water.
2. Remove tails or mask off surrounding area. Apparently removing coupe tail lights requires breaking off a clip so I chose to mask off the area with newspaper.
3. Apply the tint spray. I used VHT Night Shades, which is a popular choice. I did 3 coats with 15 minute drying times between coats. It was pretty hot out which helped.
4. After the final coat of tint, I waited 1.5 hours and then wetsanded both tails with 1000 grit sandpaper.
5. I started applying clear coats. I did 6 coats, again, 15 minutes between.
6. Wetsanded the clear coat with 2000 grit after waiting 2 hours.
7. Compounded and polished both lights.
EDIT: Went outside today and noticed some orange peel in the lights so I wetsanded with 1500 grit, then again with 2000, then compounded and polished. Now they're super smooth.
Now, here's what you were waiting for, pics!
You can see the fade and cracking in the lenses here:
Here's the final results:
Cracks are gone!
They look great!!!
Please tell me you live in Colorado so I can pay you to do mine haha.
Old Jul 28, 2016 | 08:04 PM
Thirty_Seven
Originally Posted by Mattyem
They look great!!!
Haha, I live in NY but I've actually wanted to move to CO since I was little. And just do it yourself. If you take your time and have some patience, I promise you'll surprise yourself.
Old Jul 28, 2016 | 08:23 PM
Mattyem's Avatar
Mattyem
I promise if you moved here you wouldn't regret it
Sounds good I'll give it a try!
Old Sep 10, 2018 | 06:44 PM
abomb951's Avatar
abomb951
Thanks for posting! Not only does it explain how to do it correctly, but it also gives me peace of mind that if I screw it up on mine (like the guy before you), it's somewhat reversible with some elbow grease!
Purist
May 4, 2016 11:46 PM
Krieger88
24
Apr 21, 2016 08:07 PM
khan_g37x_
Apr 7, 2016 05:22 PM
G37xS-Life
Apr 6, 2016 10:02 AM
Krieger88
Mar 29, 2016 08:18 PM
