Headlight? Ballast?
Old Mar 24, 2016 | 10:20 PM
jdavila35's Avatar
jdavila35
Headlight? Ballast? Please HELP!
I have a g37 coupe, the passengers headlight went out. I changed the ballast. The headlight was working perfectly fine until today. There is condensation inside the headlight. Could it be that the ballast got wet again? Could I bake it in the sun and reapply more silicon?
Old Mar 26, 2016 | 12:26 AM
cnote1115's Avatar
cnote1115
subscribed Mine isn't working either is there a fuse for headlights ?Low beam and high beam out
Old Mar 26, 2016 | 11:43 PM
jdavila35's Avatar
jdavila35
The fuse box is where the battery is at on the side. You should try and change the fuses first. If not. Try and take the ballast of the other side and put it on the side it doesn't work. If it doesn't work then it could be you have burned out bulbs. If it does work then it's the ballast. I bought a ballast on ebay and it works really well. Make sure you don't have any water in the headlight.
Old Mar 27, 2016 | 03:08 PM
cnote1115's Avatar
cnote1115
Ballast fixed mine also
jacob sami
Apr 11, 2016 07:24 PM
jcm707
Mar 19, 2016 10:56 PM
xeus
Mar 14, 2016 01:52 PM
sho423
Mar 7, 2016 12:22 AM
itshere
Feb 26, 2016 05:40 PM
