Official TRS XB LED direct fit foglights Group Buy! Don't miss out!
Old Nov 27, 2015 | 07:30 PM
  #151
ZahyMatar's Avatar
ZahyMatar
Is it normal for the foglights to have a gap with the chrome shroud or should it sit flush?
Old Nov 27, 2015 | 08:50 PM
  #152
JakRipper's Avatar
JakRipper
Its a very minimal gap
Old Nov 29, 2015 | 09:02 PM
  #153
VIVID's Avatar
VIVID
Pyroclastic Flow
Alternate Installation Method
So I was browsing the FSM (bored) and I came across a possible alternative fog light installation method.
It seems that one can swap the fog lights out without a bumper removal. In my case the LT CAI and the replacement WW bottle are blocking rear access.
Rochester, what do you think? You seem to take the bumper finisher off with some regularity. . It all seems held in with pawls and the 8mm nut.
Or am I way off base? I don't mind removing the bumper, I just need a second pair of hands so nothing is damaged and I don't want to wear out my welcome with those hands.
Sean
Old Nov 29, 2015 | 09:10 PM
  #154
Mik3G37S's Avatar
Mik3G37S
Yes the fogs can be removed from underneath by removing the under tray, I mentioned it before on Facebook groups where I posted up the group buy as well, didn't realize I didn't mention it here, or maybe I did. Either way bumper removal is not necessary at all to replace them
Old Nov 29, 2015 | 09:14 PM
  #155
eurtsx's Avatar
eurtsx
I need to install my TBW aluminum undercarriage cover this weekend, so I'll do both at the same time.
Old Nov 29, 2015 | 09:21 PM
  #156
VIVID's Avatar
VIVID
Pyroclastic Flow
Thanks Mike.
The DIY did have similar instructions. I was wondering if the bumper grille snaps out if you push it from behind? Or can you pry it out from the front? My issue is getting to the back of the FL from behind due to the tube for the CAI and the reservoir.
Sean
Please ignore this post if you have a 'standerd' (that's how it's spelled in the FSM) bumper. The bumper grille only applies to a 'Sports' (ibid) bumper. In my case, I can pry off the finisher and remove the bolt from behind to remove the FL.
Old Nov 29, 2015 | 09:58 PM
  #157
If you pull back the inner wheel well lining, turn the wheel inward, you can access the fogs through there. At least, thats how I remember it. I've never removed the bumper, but i have removed the fogs a number of times.
Wish I could be more solid on this, Sean, but I'm holding off on this mod until Spring.
Old Nov 29, 2015 | 10:00 PM
  #158
MaQG37's Avatar
MaQG37
Originally Posted by VIVID
Thanks Mike.
Sean
Please ignore this post if you have a 'standerd' (that's how it's spelled in the FSM) bumper. The bumper grille only applies to a 'Sports' (ibid) bumper. In my case I can pry off the finisher and remove the bolt from behind to remove the FL.
Sean, you can simply pull the fog light chrome trim off with your hands . There is 4 tabs on that trim. Start with pressure on the 2 points on one side, then, to the other. After that, remove the fender liner plastic tab to get access to the 8 mm bolt holding in that fog. You're going to have to turn the wheels to full lock to get access to the respective side.
Once the 8mm bolt is off, you can push the fog light out from behind the bumper. On the passenger side, it gets more tricky with the windshield washer resorvior. You're going to have to do this all by feel. I highly reccomend using a small 8mm cresecent wrench to remove that bolt. You won't have room for a ratchet + 8mm on the passenger side. Any more questions, feel free to PM me.
Old Dec 6, 2015 | 12:32 AM
  #159
lobuzz311's Avatar
lobuzz311
FUUUUU.....!!! I got everything ready to install these tonight, and it turns out that my package did not include the connectors!
Did anyone else have the same issue?
Missing these:
Official TRS XB LED direct fit foglights Group Buy! Don't miss out!-uxpc3xqh.jpg
Old Dec 6, 2015 | 01:06 AM
  #160
VIVID's Avatar
VIVID
Pyroclastic Flow
That sucks!!!!
Feel for ya. Mine was complete. Installed last night. You'll get it straightened out and forget about this setback when you see them installed. Good luck!!!
Sean
Old Dec 6, 2015 | 02:55 AM
  #161
lobuzz311's Avatar
lobuzz311
Thanks. Hopefully TRS can expedite the parts. I'm guessing I won't hear back from them until Monday morning at the earliest, though...
Old Dec 6, 2015 | 08:08 AM
  #162
Excellent. Don't be shy with the camera at dusk this evening.
Old Dec 6, 2015 | 06:38 PM
  #163
eurtsx's Avatar
eurtsx
Missing these:
Thanks for pointing that out. Mine didn't come with the connectors either. I'll be sending them an email tonight. Thanks again!
Old Dec 6, 2015 | 06:40 PM
  #164
Dj1ofDet's Avatar
Dj1ofDet
Any chance there is still enough interest to get another promo coupon activated from TRS? I now need new fogs, since I discovered some road debris busted my OEM ones up.
Old Dec 6, 2015 | 07:54 PM
  #165
eurtsx's Avatar
eurtsx
This literally just happened and from what I can tell, over 30-40 people purchased them. Better find more people!
