Help HID bulbs keeps turning off
Does anyone know what might be the problem with the HID bulb if it turns off sometimes, just one side? I thought it might be the bulbs so I had them replaced but same problem. When it goes off I turn the switch off and on and it works again but after a while it goes back off. Would it be the ballast or igniter? I had the battery replaced from AAA since they said it was getting weak. The dealer said it could be the battery isn't strong enough that could be causing this problem.
The bulb is going out. Pick up a nice upgraded set as you wont want to replace just the one. The color output on the new bulb won't match the faded color on the older bulb.
Get some replacements here. Choose your color based on the scale below.
D2S Morimoto XB XB35 XB55 OEM HID D2S Xenon headlight bulbs lamps headlamp replacement Philips Osram CBI 85122
I just installed brand new headlights modded by 180customs and installed Diode Dynamics DS2 bulbs before I tested the new lights. The driver side HID doesnt turn on initially and I have to cycle the lights and high beams to get them to come on. Well, the light will turn on initially for a brief moment then go out. Each time I turn them all the way off, then full on, the light will come on for a split second then go out. After a few cycles of this they come on and then seem to work fine. Not sure if 180customs didnt do something right in that light, or if the new bulb is bad...
I know thats the next step to troubleshoot. I just got everything put back together and I will have to try that later. They added angel eyes and iron man lights so maybe there is a possibility something didnt go right there. Im leaning more towards the bulb right now since I will assume they tested my lights prior to shipping them to me. Thanks for the input, ill let you know what I find out. It wont be today though.
If your car was built pre-2011 and you are having issues, then it isn't the bulbs.
Either way, keep us posted so we can take care of you and 180Customs
Thanks,
Nick C.
If your G37 was built after 2011, our bulbs will not function correctly with the factory ballasts, hence why we don't have them listed for those model years.
Thanks,
Nick C.
Thanks,
Nick C.
There is nothing wrong DD bulbs, if your car is 2011 and late model, the ballast is very picky and only compatible with OEM bulbs. If you use DD bulbs, they will most likely flickering and not work properly. The only bulbs that work are D2S Osram.
D2S Osram Xenarc 66240 CBI HID Bulbs - Xenon Headlight Bulbs - The Retrofit Source
Thanks,
Nick C.
Thanks,
Nick C.
You sure about this, I had to go back to the stock HID's on my 09 sedan, I have 3 sets of DD HID's and none of them would the passenger side light come on? Stock HID every time it work, DD HID I would have to flip the high beams or turn the switch on and off a few times before it would come on. But would never auto turn on :/
