Help HID bulbs keeps turning off
Old Oct 9, 2015 | 02:27 PM
Diode Dynamics's Avatar
Diode Dynamics
If you don't have the HID bulb seated correctly it could cause that issue
Nick C.
Old Oct 16, 2015 | 12:49 PM
ANMVQ's Avatar
ANMVQ
Originally Posted by teonguyen
There is nothing wrong DD bulbs, if your car is 2011 and late model, the ballast is very picky and only compatible with OEM bulbs. If you use DD bulbs, they will most likely flickering and not work properly. The only bulbs that work are D2S Osram.
D2S Osram Xenarc 66240 CBI HID Bulbs - Xenon Headlight Bulbs - The Retrofit Source
Wonder if this means I had one of mine replaced on my 09 with a newer ballast.
Cause no matter what I do the passenger side light will not turn on unless I flip the lights like 4 or 5 times. If I buy bulbs for a 11+ will they work ,since I think the drivers side is still the original one
Old Oct 16, 2015 | 03:04 PM
Roblom's Avatar
Roblom
If it turns on and switches off by itself sometimes it's almost definitely a ground problem or a defective balast.
Old Oct 19, 2015 | 04:42 PM
ANMVQ's Avatar
ANMVQ
Mine wont even turn on, unless a flick it 4-5 times. I'm going to try these
D2S Morimoto XB HID Bulbs - Xenon Headlight Bulbs - The Retrofit Source
Old Nov 14, 2015 | 04:04 PM
superjoey's Avatar
superjoey
I just installed the Morimoto XB 6500K two nights ago. They fit the ballast and turn on without any problems so far. I have a 2013.
timc00k
Feb 15, 2017 09:15 AM
stevo4756
Oct 9, 2015 01:54 AM
parkern
Oct 1, 2015 10:15 PM
halfbreedcuban
Sep 27, 2015 08:58 AM
