Problem w/ Cruise Control and Heated seats
Old Jul 24, 2015 | 07:23 AM
therzdae's Avatar
therzdae
Question Problem w/ Cruise Control and Heated seats
Howdy Y'all,
I have owned my 2011 G37S for about a month now, in that time I realized I didn't check the car enough before buying butttt too late to b*tch about it now.
So Both my cruise control, and my heated seats don't work...
I have done extensive research on this forum, TONS of information but none of them fit my issues besides the basics like checking fuses (already did no issue), or if I was doing something wrong so I also read a good bit of our manual on here.
So the cruise control will turn on but never engage, I believe the "cruise" comes up when I turn on but when I hit it to set the speed the speed number never comes up or set at all... I have also thought "maybe the digits are just broke" so I followed manual instructions and would have "set" it but it doesn't engage. So I have checked the fuses those are good, my next step was going to be taking out the switch and cleaning it (maybe someone spilt a drink on it) However if someone has ran into this I would love to know experience, or possible fixes, or even something to check in addition to switch?
Now the 2nd issue
The heated seats down turn on, when I twist either **** I believe the light on the **** is suppose to light up, mine does not. Again thought maybe just the light went out so I cranked them both up drove it for well over a hour never got any heat... So checked fuses, they good, So next step is also taking out the switches and clean/check them... Though maybe someone has an idea before I go about this also?? [/SIZE][/B][/B]
Now I know the car has been in a wreck in the driver side front end, Maybe something is located around there that can affect these two?
Any advice would be thoroughly appreciated!!!
Old Jul 24, 2015 | 04:18 PM
ANMVQ's Avatar
ANMVQ
Check to see if they run on the same fuse , Heck just check the fuses. If not there might be a wiring issue from the accident :/
Old Jul 24, 2015 | 05:38 PM
Gearratio's Avatar
Gearratio
Cruise control
Does your car have intelligent cruise control, it won't engage if your too close to another car up too about 6 car lengths away.you would know if u have a sensor in your lower grill, also if the sensor is dirty it won't work either.as far as the seats I'm sorry don't have answer for that,hope u figure it out.
Old Jul 24, 2015 | 07:17 PM
chuckie311's Avatar
chuckie311
Drop A Gear and Disappear
I had my heated seats go out after 2 years..thankfully they were under warranty and didnt have to worry about them.. they had to replace 2 seat packs for mine
Old Jul 23, 2019 | 12:51 PM
Surfnazi's Avatar
Surfnazi
The **** is a potentiometer so its misreading like a fuel gauge sensor in tank would if it didnt read right voltage
Old Jul 31, 2019 | 07:28 PM
GoatBeard's Avatar
GoatBeard
Not sure about the heated seats, but I had a similar problem with my cruise control. Next time you're out, try lifting up the brake pedal with your foot, and hold it up, while setting the cruise speed. There is a pedal actuator type button (don't know the technical name) under the pedal. There is a nut you can adjust it with and set the brake pedal actuator closer to the pedal once the pedal is released. I can take pics and describe it more if needed and you find that the foot under the pedal, in fact, has cruise control engage.
Old Aug 1, 2019 | 10:38 PM
Rollo's Avatar
Rollo
Totally this on the cruise...the guy I bought my G from used had a video of how to fix this I think. If you google it you can probably find the solution. I was having this problem when driving home my car that I had just purchased and I called the dealership and the guy told me to hold up on the brake and it worked. I made the adjustment and no further problems for 3+ years so far...
ctng37
Jul 27, 2019 08:45 PM
DwD
Jul 14, 2012 01:08 AM
Axion
Sep 14, 2011 06:16 AM
lordg
Canada
Sep 30, 2010 10:41 AM
MikeyMike
The M - Spot
Mar 6, 2006 03:49 PM
