LED Fogs
Old Jul 25, 2015 | 05:49 PM
NYYanks7823's Avatar
NYYanks7823
Was able to install them today through the wheel well. Opted not to wire the halos so pretty much plug and play. They look really bright and match the color of stock hid head lights very well. We'll see how they look at night!
Old Jul 25, 2015 | 06:18 PM
jroyalty7's Avatar
jroyalty7
Hey man glad you got em done, sorry I missed your question yesterday but at least you figured it out.
Old Jul 26, 2015 | 01:39 PM
Epiphany's Avatar
Epiphany
Were you able to change the passenger side through the wheel well also? When i was changing my headlight through there it didn't look like I'd have access to the fog light because of the washer fluid tank.
Old Jul 26, 2015 | 09:03 PM
MaQG37's Avatar
MaQG37
You got to remove it.
Old Jul 26, 2015 | 09:49 PM
jroyalty7's Avatar
jroyalty7
When I did this I was able to work around the reservoir through the wheel well, but it was a serious PIA... take the bumper off. There are plenty of diy's and it's pretty easy
Old Aug 6, 2015 | 07:30 PM
NYYanks7823
Have you noticed quite a bit of light scatter with the leds. Almost like I have my high beams on. Maybe I need to play with the adjustment screw to change the height of the beam?
Old Aug 7, 2015 | 07:49 PM
NYYanks7823
I know you also have these light jroyalty. Have you noticed the light beam scatters above the beam if the headlights?
Old Aug 7, 2015 | 08:23 PM
jroyalty7's Avatar
jroyalty7
If you mean the brightness when the full fog leds are on, then yeah I notice a difference where they combine with the headlights for a wider projection. They're very bright but I like it
Old Aug 7, 2015 | 08:56 PM
NYYanks7823
No I mean that it appears as if I have my high beams on with these fogs because the light projects upwards as well. If in point my lights at my garage door, the fogs are well over the cut off line from the headlights.
Old Aug 7, 2015 | 09:04 PM
jroyalty7's Avatar
jroyalty7
Ohhh gotcha... no sorry man I don't have that issue... maybe on install they didn't settle in correctly before you buttoned everything up? Not to sure on this one...
Old Aug 7, 2015 | 09:06 PM
NYYanks7823
We'll that's reassuring then. Will have to check everything this weekend as see what the issue is.
Old Aug 8, 2015 | 08:13 AM
xpcgamer's Avatar
xpcgamer
Why didn't you guys just install 6k LEDS bulbs from VLEDS? I had them in my Lexus and just moved them to the G. Bright as hell and no glare.
Old Aug 8, 2015 | 11:09 AM
qmantran's Avatar
qmantran
I got vleds 5k fog lights. They are the expensive $100 ones that are 2800 lumens.
I suggest everyone to stay away from the cheaper $60 ones from vleds . They are only 850 lumens and burn out in 1 year
Old Aug 8, 2015 | 11:29 AM
  #29
jroyalty7's Avatar
jroyalty7
I personally like the halos which is why I bought them, I use that most of the time.
Old Aug 8, 2015 | 11:36 AM
  #30
xpcgamer's Avatar
xpcgamer
Here they are installed in the Lexus. I go them in February 2013 and they are still bright as hell in my G today. The original link says they are no longer available thou.
They together with my DDM 6k 55 watt kit.
Attached Thumbnails LED Fogs-20130223_192232.jpg   LED Fogs-20130223_192131.jpg
timc00k
Feb 15, 2017 09:15 AM
2K1 6T8
Oct 6, 2015 07:40 PM
Landshark
Sep 29, 2015 11:20 PM
SheLLz
Sep 24, 2015 08:02 PM
