2011 Fog Light Relay Location?
Old May 16, 2015 | 09:28 PM
notTHATgood's Avatar
notTHATgood
Question 2011 Fog Light Relay Location?
My fogs went out. I tested to see if they were getting any power as I just got new bulbs (diode dynamic XML2) and they were not. I checked the fuse next to the battery and everything was fine. I'm thinking it could be my fog light relay but I cannot for the life of me find where it is (if it even exists). Can anyone help me locate it?
Quick note: it just rained for the first time here in a while and the fogs went out the day it rained. I don't know if there is a correlation but thought I'd throw that out there.
Thank you in advance.
Old May 17, 2015 | 07:32 AM
telcoman's Avatar
telcoman
Check out the FSM for your year and model
Telcoman
Old May 18, 2015 | 11:11 AM
Diode Dynamics's Avatar
Diode Dynamics
The XML2's are fully waterproof FWIW
Check your fuses and wiring to make sure everything is intact and in good working condition
Nick C.
Old May 18, 2015 | 11:37 AM
Flakman's Avatar
Flakman
Here's a link to the FSMs Infiniti G35 / G37 Factory Service Manuals - NICOclub
Old May 19, 2015 | 09:11 PM
notTHATgood
Thank you for all of the replies! I called the dealership looking for IPDM relay which turns the integrated front fog lamp relay ON and they said they only sell that relay as an "entire unit" which costs $900. What a joke!
Has anyone needed to replace any of their relays for exterior lighting or any of the relays located in the fuse box that is on the side of the battery compartment (parallel with the side wall passenger side)? Was it necessary to replace the entire unit or were any of you guys able to replace as a separate unit?
Seems like a nightmare to pay $900 for the entire fuse box unit just to get power to my fogs again.
I'm going to check my switches to make sure that they are all functioning correctly before moving forward with a solution. I'll keep you guys posted.
In the meantime, any replies with experiences in regard to my questions above are much appreciated.
<3
Old May 20, 2015 | 07:48 AM
telcoman's Avatar
telcoman
Try removing the replacement bulbs and go back to stock bulbs before troubleshooting with a multimeter
Telcoman
Old May 20, 2015 | 03:54 PM
notTHATgood
Telcoman
That wouldn't be of any help because the fogs aren't getting any power. It's not a bulb issue.
Old May 23, 2015 | 03:39 PM
telcoman's Avatar
telcoman
Have you looked at the FSM?
http://www.nicoclub.com/FSM/G37/Coupe/2011/EXL.pdf
Just from a quick read I think you have a bad connection otherwise you would have other lights not working.
Did you check the 15Amp fuse #58 as described in the FSM?
Front fog lamp IPDM E/R #58 15 A
See page EXL 48
Take those bulbs out and put the OEM bulbs back in.
If still not working take it to a Infiniti dealer and let a qualified technician find your problem.
Page
EXL-30
< SYSTEM DESCRIPTION >
[XENON TYPE]
DIAGNOSIS SYSTEM (IPDM E/R)
Diagnosis Description
INFOID:0000000006934979
AUTO ACTIVE TEST
Description
In auto active test mode, the IPDM
E/R sends a drive signal to the follo
wing systems to check their operation.
• Oil pressure warning lamp
• Front wiper (LO, HI)
• Parking lamps
• License plate lamps
• Side maker lamps
• Tail lamps
• Front fog lamps
• Headlamps (LO, HI)
• A/C compressor (magnet clutch)
• Cooling fan (cooling fan control module
Operation Procedure
1. Close the hood and lift the wiper arms from the
windshield. (Prevent windshield damage due to wiper
operation)
NOTE:
When auto active test is performed with hood opened, sprinkle water on windshield beforehand.
2. Turn the ignition switch OFF.
3. Turn the ignition switch ON, and within 20 seconds, press the front door switch (driver side) 10 times.
Then turn the ignition switch OFF.
CAUTION:
Close passenger door.
4. Turn the ignition switch ON within 10 seconds. Af
ter that the horn sounds once and the auto active test
starts.
5. The oil pressure warning lamp starts blinking when the auto active test starts.
6. After a series of the following operations is
repeated 3 times, auto active test is completed.
NOTE:
When auto active test mode has to
be cancelled halfway through test, turn the ignition switch OFF.
Never try to fix anything that isn't broke.
Telcoman
Old Jun 17, 2015 | 12:36 PM
notTHATgood
So...ended up taking the car to the dealer and I hate to post this and admit that I completely over-looked that the switch was off for the fogs. I thought that the ***/switch that turned the headlights on controlled everything and I guess tunnel vision got the best of me. Fought 2 hours of traffic at 6am yesterday to get to the dealer first thing in the morning and I bet I was the joke of the day after I left...
Thank you all for you help - I hope I got all of the stupid out of my system for the year.
Old Jun 17, 2015 | 12:41 PM
AroundTheG37's Avatar
AroundTheG37
LOl, now that's funny.
superjoey
31
Mar 22, 2023 11:56 PM
Thedbarz
33
Feb 9, 2016 12:05 AM
G37xhibeet
Sep 4, 2015 03:00 PM
bikerjosh
Aug 19, 2015 11:26 PM
