Led foglights
Old May 11, 2015 | 03:30 PM
BrianJC's Avatar
BrianJC
DD, I've put in and they are very straight forward. Just unplug the old and plug in the new and your off and running. The passenger side is tight but it will go in. I had to loosen the washer fluid (1 nut) to get it to move just a little.
VLEDs look to be plug and play as well, no harness but I can't say for sure.
Old May 11, 2015 | 04:16 PM
SS2006's Avatar
SS2006
^thanks
mind sharing some quick DIY on how to replace fogs
ive replaced my front grille before, I assume its in that same area
Old May 11, 2015 | 04:23 PM
Come at the fogs by peeling back the wheel well plastic enough to get your arm in there.
Turn the wheel in, unbolt the lining from underneath at the corner, remove a clip towards the middle, and pull it back. Takes a little effort. Get down and study it, you'll figure it out.
Old May 11, 2015 | 04:28 PM
Diode Dynamics's Avatar
Diode Dynamics
Our LED replacement bulbs are 100% plug and play, no relay harnesses are needed.
The XML2 is also waterproof FWIW
Nick C.
Old May 11, 2015 | 04:29 PM
jay10's Avatar
jay10
DD is the way to go. Always been happy with them.
Old May 11, 2015 | 07:29 PM
SS2006's Avatar
SS2006
Can someone confirm the fog light size of a 2010 Infiniti G37x sedan. I have heard its '9006', however in the reviews here the guy says they don't fit and it should have been H8 instead (which is what is on the 2011 sedans)
2009-2010 Infiniti G37 Sedan Fog Light LEDs (pair) - G37 Sedan - Infiniti - Bulbs By Vehicle - Lighting
I need to know before I order, hopefully DD can chime in
Old May 11, 2015 | 08:02 PM
qmantran's Avatar
qmantran
Just curious is there a reason why you are going for the DD over VLEDs?
According to one reviewer
"I have a 2010 G37xS Sedan and ordered these fog lights thinking it would fit, but it didn't. They are going to send you bulb size 9006, but they're actually bulb size H8."
I know in 2010 all G37 underwent a face lift. New headlights, front bumper, new grill, and all fog lights relocated to the bottom of the bumper. I think it's safe to say all 2010-2013 G37 use H8 fog light bulbs.
That reviewer on DD website said he was sent 9006 which were "WRONG" and he needed H8. He has a 2010.
I used H8 HID bulbs for my fogs. My car is a 2011.
Originally Posted by Diode Dynamics
Our XML2 replacements are 1,410 lumens (measured). Key word there is measured
Watch out for vendors who provide rounded-off lumen numbers, or "calculated" figures.
We measure all of our lighting products in-house to provide accurate figures for our customers:
How LED Bulbs Are Measured: Integrating Sphere Overview - YouTube
We've also performed tests on most other vendor's products to verify their claims
Good vs. Bad LED Bulbs: Testing Current - YouTube
The XML2's are indeed a bit expensive, but that's because they utilize genuine components and the most advanced construction methods. The 4000K and 5000K LEDs used in construction of the Natural and Pure white options are more expensive for us to produce due to the LEDs, so we had to adjust the price slightly.
They produce exceptional output, and come backed with a 3-year limited warranty.
If you have any questions, feel free to give us a call: (314) 205-3033
We are proud to be a supporting vendor on this forum
Thanks!
Nick C.
That's interesting. Just curious, have you guys tried testing your bulbs vs VLEDs? I've been a long time VLED user for 4+ years and never had problems with their customer support and quality of products.
Old May 11, 2015 | 09:07 PM
WillCo1's Avatar
WillCo1
Nick C.
2010 Coupe, website says hi-power LEDs no longer available?
Also, no Yellow LEDs?
Any other options for brighter fogs? (besides an hid ballast kit)
Or am I stuck with these crappy factories?
Old May 11, 2015 | 09:52 PM
qmantran's Avatar
qmantran
What bulb size does the 2010+ Coupe use for fog lights?
Old May 11, 2015 | 10:12 PM
WillCo1's Avatar
WillCo1
H1
The foglights are built into the headlight housing.
Old May 11, 2015 | 10:20 PM
qmantran's Avatar
qmantran
LMZ H1 25W 3000LM HIGH OUTPUT LED HEADLIGHTS FOG LIGHTS - Shop Bulb #
timc00k
Feb 15, 2017 09:15 AM
Landshark
Sep 29, 2015 11:20 PM
Allboutcali
Sep 26, 2015 03:43 PM
SheLLz
Sep 24, 2015 08:02 PM
