Help Removal of this piece from the front bumper
Old Mar 19, 2015 | 05:09 PM
Flakman's Avatar
Flakman
Going to add some lights to the blanks in the lower corners of the bumper (Nothing there for '09, but '10 and up have fog lights there). Need to know if I need to get to them from the wheel well or by removing the cover from below.
Thanks
Old Mar 19, 2015 | 07:16 PM
vqsmile's Avatar
vqsmile
Thanks
It's easy to access them from below; just drop the covers under there. You may find that you need a later model windshield washer reservoir though, as it extends down on the passenger side right behind that cover. The later models have a bottle of a different shape that allows more clearance for the fogs.
Old Mar 19, 2015 | 08:05 PM
G37sTimCA's Avatar
G37sTimCA
I'd be interested in your set up. There are a couple I've seen on here that look good but not quite exactly what I want.
Good luck and keep us posted!
Old Mar 20, 2015 | 01:30 AM
Flakman's Avatar
Flakman
Thanks for the info and will do. Will be adding individual LEDs as drls just to clarify. Will take pics of the process.
Old Mar 23, 2015 | 12:47 PM
Flakman's Avatar
Flakman
Well, I took down the cover below the engine only to find that with (at least the '09) that part is part of the bumber itself. And since it is molded to look like expanded metal, it's not gonna be a very even surface. So I'm back to the drawing board in figuring out what I want to do as far as a DRL mod.
Old Mar 24, 2015 | 09:03 AM
GAWD's Avatar
GAWD
FYI for anyone following, my 2013 (so presumably all 2010+) non-sport sedan front bumper is the same way. What appears to be a perfectly removable black mesh panel on the front side is actually part of the entire bumper mold. Here is a photo of the drivers side taken with the wheel well liner removed.
gsdfgsdgasdg_zpsa539d705.jpg?1427201862276&1427201874431
Old Mar 24, 2015 | 11:15 AM
Flakman's Avatar
Flakman
That's interesting. I have the G37xS, yet this is molded. Though I don't believe they started putting fog lights there til '10+ so all of the bumpers for '08/'09 may be that way.
Old Mar 24, 2015 | 11:45 AM
vqsmile's Avatar
vqsmile
Yeah, the 08 is not that way.
Old Mar 27, 2015 | 03:44 PM
Flakman's Avatar
Flakman
Couldn't find a good Napoleon Dynamite "Lucky" gif to post.
Thedbarz
33
Feb 9, 2016 12:05 AM
m3clubracer
Aug 26, 2015 07:36 AM
leanlikeacello
Aug 15, 2015 02:14 AM
Amarsingh
Aug 8, 2015 01:31 PM
G37Sgirll
Aug 5, 2015 06:55 PM
