Painting headlight housing?
Old Feb 12, 2015 | 07:02 PM
nitsua26's Avatar
nitsua26
I've seen how to do it but I'd like to see someone who's actually done it and could give me some pointers and if its worth the hassle. Also, what kind of paint to use to paint the housing? Thanks.
Old Feb 12, 2015 | 08:55 PM
SoonerG37's Avatar
SoonerG37
While doing this isn't the most difficult, I found it to be a real hassle. That being said, I LOVE the outcome!
Once you get the bumper off and headlights removed, the "fun" starts. Follow the DIY step by step that's on the forum, it will help tremendously.
I used black engine enamel to handle the heat from the lights. Just pick the color you want!
VHT Paints/Satin black high temperature Engine Enamel SP139 at AutoZone.com
I highly recommend using the OCI butyl to reseal, preventing you from having to do everything again. Like me.....
OCI Butyl Rubber Glue
It should be obvious that you should take your time baking/prying the headlights apart. As well as take your time prepping and painting for the best outcomes.
While in there/waiting for paint to dry it's worth swapping the stock lenses for the TSX lens! While this isn't necessary, you'll love the outcome!
TSX-R - Clear Lenses from The Retrofit Source
This is how mine turned out!
GeezerB
Car Care & Detailing
12
Jan 23, 2017 07:00 AM
ck1109
Oct 15, 2015 11:06 PM
2K1 6T8
Oct 6, 2015 07:40 PM
stm37s
The M - Spot
Oct 1, 2015 06:53 AM
Chris_M
Sep 25, 2015 08:38 PM
