Replacing door panel trim
Old Dec 30, 2014 | 08:41 AM
JT2014's Avatar
JT2014
The silver trim on my drivers door panel is peeling. Is this replaceable? Or do I have to buy the whole door panel? I see the trim that goes across the door pulls as separate parts. I haven't seen the silver panels that run across the top.
Is there a DIY for this?
Thanks
Old Dec 30, 2014 | 09:23 AM
ILM-NC G37S's Avatar
ILM-NC G37S
I had to replace the door handle/pull trim piece- cost around $25- and it just pops right off of the door pull.
If your talking about the trim strip (like where the memory seat buttons are) you will more than likely have to remove the door panel which is very easy to do. When I had my panels off for the mirror swap I honestly didn't pay attention to the trim pieces. There is a DIY on the forum which is very useful. This picture shows the different trim pieces and their initial part number:
Attachment 109425
I would recommend try removing the trim piece you want replaced and copy the part number that's stamped on the back to get the full part number.
Hope this helps!
Amaadkhan2k
Oct 4, 2024 01:20 PM
OneSickBlackG
Jan 6, 2016 08:49 AM
andrewk523
Nov 11, 2015 05:49 PM
lobuzz311
Sep 15, 2015 10:09 AM
pal51961
Sep 6, 2015 05:34 AM
