lower door lights
Old Oct 30, 2014 | 09:49 PM
cdmuile's Avatar
cdmuile
lower door lights
So, I'm trying to replace the lower door lights (puddle lights?) Can't seem to do it. How do I unhook the oem light pod??
Old Oct 31, 2014 | 12:06 AM
Azngonkick's Avatar
Azngonkick
use a flat screwdriver and pry the pod out of the door, from there you use the flathead again to from it open...i cant think of which part exactly but you'll figure it out by looking at it.
Old Oct 31, 2014 | 12:30 AM
xxg00w0's Avatar
xxg00w0
pry!!!!!
Old Oct 31, 2014 | 07:14 AM
ILM-NC G37S's Avatar
ILM-NC G37S
Just grasp the puddle lamp assembly from the bottom and pull forward/away from the door. It will pop right out.
Personally, I wouldn't use a screwdriver or other sharp metal object. One slip and you'll risk tearing the door or breaking the plastic assembly.
To each their own, however.
Good luck.
Old Oct 31, 2014 | 08:00 AM
JT2014's Avatar
JT2014
Be gentle & you should be ok. It's not hard to do but you don't need to go hulk on it.
Old Oct 31, 2014 | 12:07 PM
ANMVQ's Avatar
ANMVQ
Pops out pretty easy, I changed mine a few weeks ago.
Old Oct 31, 2014 | 12:39 PM
quakerroatmeal's Avatar
quakerroatmeal
Pops out from the bottom. If you use a flat head wrap a towel around the head so you don't scratch/scrap anything. If you look under there you'll see an indention.
G37xhibeet
Nov 15, 2016 09:29 AM
Thedbarz
33
Feb 9, 2016 12:05 AM
Upscale Speed
Aug 6, 2015 04:08 PM
VIVID
Aug 3, 2015 02:40 PM
