Help with HID fog light install
Old Aug 13, 2014 | 01:25 AM
cali_g37's Avatar
cali_g37
What is the best way installing passenger side fog light bulb? Do you guys remove the whole bumper? or remove the washer container? I tried everything and I am simply stuck. Thanks.
Old Aug 13, 2014 | 01:27 AM
mpegripper's Avatar
mpegripper
i took off the bumper
Old Aug 13, 2014 | 01:35 AM
cali_g37's Avatar
cali_g37
is there a diy for 2010+?
Old Aug 13, 2014 | 08:27 AM
Daddy Fat Sacs's Avatar
Daddy Fat Sacs
just remove the engine splash gaurd sheild from underneath the car along with the bottom bolts connecting the bumper and fender together, then you can access the fogs very easily. The bumper is very easy to take off as well and there is a DIY on the bumper removal.
Old Aug 13, 2014 | 10:22 AM
GoFightNguyen's Avatar
GoFightNguyen
Because Racecar
Take the bumper off, why are people so averse to removing the bumper?
Old Aug 13, 2014 | 02:51 PM
mpegripper's Avatar
mpegripper
the 2010+ bumper is different slightly from the DIYs on here. There are two bolts in the wheel well area for 2010+
Old Aug 13, 2014 | 03:35 PM
cali_g37's Avatar
cali_g37
Thank you mpegripper, I just notice that. Still wondering if anyone has diy for 2010+ bumper removal.
Old Aug 13, 2014 | 04:15 PM
mpegripper's Avatar
mpegripper
all screws on the bottom plastic piece, 2 the in the wheel well on each side, the 4 or so expanding rivets when you open the hood.
lastly there is one on each far end when the hood is open right where teh fender meets the headlight area.
the 2009 DIY shows those in these pics:
so its literally the same, just the extra bolt in the wheel well
Old Aug 13, 2014 | 05:12 PM
GoFightNguyen
Because Racecar
Is there? I've got a 2012 coupe and I only have one bolt in each of the wheel wells.
superjoey
31
Mar 22, 2023 11:56 PM
Thedbarz
33
Feb 9, 2016 12:05 AM
sydnrusty
Nov 21, 2015 10:42 PM
bikerjosh
Aug 19, 2015 11:26 PM
