2010 G37x Coupe driver side low beam turns on and off
Old May 9, 2014 | 07:41 PM
AzNBoY92's Avatar
AzNBoY92
Hey guys been looking through several different forums and could not find an answer of what's going on. I installed 6000K D2S bulbs last week and they worked fine when I first installed but couple days now I noticed that whenever my headlights auto on my passenger side turns on fine but driver side turns on and off in a second. Only fix currently is switching the headlights on and off 2-3 times then the low beam starts working again. Pretty moderate hassle. Any ideas? Is the connection loose or the ballast module is messed up? Note it worked fine for OEM bulbs.
Old May 9, 2014 | 08:13 PM
pmartell12's Avatar
pmartell12
sounds like a bad bulb. the old bulbs had a ballast and an igniter, they are in one unit now, and if the bulb isn't working right, it wont stay lit.
Old May 9, 2014 | 08:26 PM
AzNBoY92's Avatar
AzNBoY92
So why does it work fine after switching headlight off and on a couple of times? That's the weird part to me, if it was bad bulb it wouldn't even start working.
Old May 9, 2014 | 08:39 PM
orson8888's Avatar
orson8888
maybe the connection is loose
Old May 9, 2014 | 09:11 PM
speedracer g37's Avatar
speedracer g37
uh. not the bulb. ignitor/ballast is bad. problem will only get worse until it won't light at all.
Old May 9, 2014 | 11:06 PM
AzNBoY92's Avatar
AzNBoY92
It was the bulb considering the stock bulbs that were in there worked fine after I put them back in, hopefully Diode Dynamics gets back to me soon, riding around with stock on one side and 6000K on other looks weird. Thank god its not the ballast/igniter that would have been expensive to replace.
m3clubracer
Sep 11, 2016 09:01 PM
drewfinity
Aug 20, 2015 08:17 PM
pcwd
Aug 12, 2015 06:54 PM
kevinmward
Aug 12, 2015 12:09 AM
Doug Crawford
Aug 8, 2015 02:08 AM
