one interior dome light is not working
Old Apr 6, 2014 | 09:57 PM
sikwidiit's Avatar
sikwidiit
driver side dome light stopped working, i out a new bulb in too see if it was the bulb but no luck... maybe fuse ?
ever append to any of you guys ?
thanxx
Old Apr 6, 2014 | 10:24 PM
GoFightNguyen's Avatar
GoFightNguyen
Because Racecar
Did you try flipping the bulb in place? Some bulbs require you to put them in a particular orientation.
Old Apr 6, 2014 | 10:27 PM
sikwidiit's Avatar
sikwidiit
yea, i did that too & no luck
Old Apr 7, 2014 | 05:16 PM
sikwidiit's Avatar
sikwidiit
anyone ??
Old Apr 8, 2014 | 09:47 AM
2008G-Man's Avatar
2008G-Man
Originally Posted by sikwidiit
anyone ??
Do you have a volt meter? Check to see if the socket is getting power. If not you have a break in the wiring somewhere. Is it the light that can be turned in manually by pushing the lens covering? If so the switch in that might be bad. Volt meter will help isolate the issue.
Old Apr 9, 2014 | 12:51 PM
GeezerB's Avatar
GeezerB
Swap with the working bulb. That will verify it's not the bulb.
superjoey
31
Mar 22, 2023 11:56 PM
Ricio1991
12
Apr 21, 2022 01:39 PM
warpeacelove
Oct 28, 2015 02:59 AM
