2013 G37 Sedan headlight bulbs replacement
Old Mar 25, 2014 | 02:58 PM
TenshiroG37's Avatar
TenshiroG37
Hi,
I been looking through the forum and can't find a guide on how to replace the headlight bulbs for the 2013 G37. I saw the guide for the 2008, but it's doesn't look like the same headlight housing for the 2013.
Does any have a guide? I just want to change parking and turn signal to LED.
Old Mar 25, 2014 | 03:06 PM
GoFightNguyen's Avatar
GoFightNguyen
Because Racecar
Hello, the headlight bulb replacement is more or less the same. It's much easier to get to the back of the headlights if you go through the wheel well. If you have aftermarket intakes, you can go through the engine bay, just twist to remove the cover, and remove the bulb.
Old Mar 25, 2014 | 05:02 PM
TenshiroG37
Thank You! Do you happen to know what LED bulb model that would produce the most lumen and best in these area? I'm using it as DRL.
Old Mar 25, 2014 | 05:09 PM
'11G37S's Avatar
'11G37S
A 1/4 mile @ a time
Originally Posted by TenshiroG37
Hi,
It's the same as it is in this video. I would take your jack out of the trunk and jack your car up a little to make it even easier.
superjoey
31
Mar 22, 2023 11:56 PM
WhyUmadMFKR510
Northern California
20
Oct 13, 2015 03:04 AM
maybeg37
Sep 8, 2015 02:33 PM
sharmelan
Aug 25, 2015 03:41 PM
aairi
Buying & Leasing
Aug 14, 2015 02:10 PM
