Led issues "service engine light"
Old Feb 6, 2014 | 03:18 PM
Luckymike74's Avatar
Luckymike74
Replaced running lights and fog lamps and my 2011 g37 and turned on service engine light. Do I need load resistors? Any help would be greatly appreciated.
Old Feb 6, 2014 | 03:21 PM
GoFightNguyen's Avatar
GoFightNguyen
Because Racecar
I would get your codes check and make sure the issue really is the lights. It's possible you might need a CANBUS adapter, but I doubt it. If you did a retrofit, it's also possible you need a relay harness.
Old Feb 6, 2014 | 03:23 PM
NJ Torque's Avatar
NJ Torque
No. Look into connections for your intake tubes/setup.
Old Feb 6, 2014 | 03:34 PM
Luckymike74
I did start it with the intake tubes off/wire disconnected to check the lights before putting them back in
Old Feb 6, 2014 | 03:37 PM
GoFightNguyen
Because Racecar
Oh, yeah. Just reset your ECU. If you leave your MAF sensors unplugged your car will idle roughly and throw lights. I made that mistake. Just disconnect the negative terminal of your battery for a few minutes and reconnect it.
Old Feb 6, 2014 | 03:59 PM
Carfanatic's Avatar
Carfanatic
Cool
BINGOOOOO, IT'S YOU INTAKES LOL , line them up carefully and if light doesnt go away remove battery cables for 30min and re plug Problem solved BUT realign intakes
Had the same issue a week ago Super Annoying
Old Feb 6, 2014 | 06:16 PM
Luckymike74
thank you guys for your input!!!! any idea's for me as far as putting different intakes on brand etc....
Old Feb 7, 2014 | 08:19 AM
PongSanity's Avatar
PongSanity
stillen gen3 cai is the best bang for your buck....
NGRBabies
Mar 25, 2016 12:38 AM
Thedbarz
33
Feb 9, 2016 12:05 AM
Badgerman
Aug 19, 2015 02:26 PM
Ali K.
Aug 5, 2015 11:49 PM
