"HELP" Windows will not fully close...!
I just picked up a 2008 G37S White on Black 6MT! But... I realized that the auto power up on both sides does not work as in one click auto down does but to put them up I have to hold it down. And when I open either door the window goes down a touch like normal but when I close the door it should go back up to seal with the door but it does not. So each time I open the door and close it the window will stay lower and lower..
Any ideas? Windows work so I am guessing a fuse or some thing?
Try resetting your windows and see if that helps.
https://www.myg37.com/forums/audio-v...dow-reset.html
You're new here. Use the search function.
Kojack
Oct 9, 2015 05:53 PM
RexHavoc
Oct 2, 2015 11:47 AM
CiViCKiDD
Sep 24, 2015 10:47 AM
