Help Question on DRL
Old Aug 5, 2013 | 06:49 PM
Samer Serhan's Avatar
Samer Serhan
Question on DRL
I bought this kit LED Daytime Running Light DRL Relay Harness Auto Control ON OFF Switch Universal | eBay
and about to start working on a project i have thought up
BUT this kit has this 'optional white wire that connects to 'Headlight +', that turns off the DRL when headlights are on
That is what i need as I don't want these on at night, as they are DRLs
what exactly is this Headlight+ I need to connect the white wire to, and where do I find it
Thanks!
Its a 2010 G37x Sedan (Canadian model)
Old Aug 5, 2013 | 07:10 PM
KEG97's Avatar
KEG97
It might be too late but I purchased this exact same product and it broke within a week. The seller was great and sent me a new one, but I was gun shy and send them both back for a full refund. I ended up buying the Phillips kit from Amazon- $75 and it contains both the DRLs and the wiring to hook it up. MUCH happier.
Old Aug 5, 2013 | 07:36 PM
Samer Serhan
C an you link? And dies it turn off once headlights are on. That's what I'm trying to figure out how to do, form a wiring perspective
Old Aug 5, 2013 | 09:07 PM
vaio23's Avatar
vaio23
I hooked mine up to my fog lights. Just tap into the positive wire that goes to your lights. Headlights are a little tricky because of ballasts, you can easily tap into parking lights.
Old Aug 5, 2013 | 09:26 PM
KEG97's Avatar
KEG97
I had these installed professionally and they hooked the wire into the parking light. I just pulled it out so my DRLs are on all the time.
Amazon.com: Philips 12820WLEDX1 DayLight 4 High Powered Luxeon LED Daytime Running Light: Automotive Amazon.com: Philips 12820WLEDX1 DayLight 4 High Powered Luxeon LED Daytime Running Light: Automotive
JG_G37
Sep 19, 2015 09:07 PM
nbast
Sep 14, 2015 12:39 PM
gdaelemans
Sep 13, 2015 09:36 PM
si_driver
Sep 12, 2015 10:38 PM
johnadlertech
Sep 11, 2015 02:07 PM
