Head light tint
Old Jun 29, 2013 | 12:53 PM
dallasbeaner's Avatar
dallasbeaner
Head light tint
Does anyone know of an affordable place where I can get my head lights tinted by someone who know what they are doing. I wanna get a clear tint place on them to avoid the faded look over time.
Old Jun 29, 2013 | 06:55 PM
tgencarelli's Avatar
tgencarelli
in nyc there are plenty of places
Old Jun 29, 2013 | 08:27 PM
quakerroatmeal's Avatar
quakerroatmeal
Laminx sells them Infiniti G37 Coupe (2008, 2009, 2010, 2011) Headlight Covers
I personally would just clean/wax them often to protect them from hazing and oxidizing
Old Jun 29, 2013 | 09:39 PM
LexiG37's Avatar
LexiG37
What kind of wax?
Old Jun 29, 2013 | 10:19 PM
KAHBOOM's Avatar
KAHBOOM
Super Moderator of Pwnage
Menzerna's Intensive polish works great. I wouldn't "tint" them because that wont necessarily prevent oxidizing. If you wanted to go for a darker look though I would consider getting the internal housing coated or painted.
Old Jun 29, 2013 | 10:31 PM
quakerroatmeal
You could use Meguiars PlastX to clean/polish/protect. I normally use this every time I wash my car to clean my headlights/tail lights.
Old Jun 30, 2013 | 03:12 PM
Darkstar752's Avatar
Darkstar752
Menzerna's Intensive Polish is a pure abrasive, basically liquid sandpaper. There is no protective qualities about the polish. Stick to a pure wax or sealant.
I would recommend just a sealant or wax. Your headlights have a coating similar to clearcoat to prevent oxidation, and until there's oxidation it's best to use a pure protective coating like a wax/sealant in order to preserve the coating on the plastic as long as possible.
Old Jun 30, 2013 | 04:41 PM
farmurr's Avatar
farmurr
Post of the year
Old Jul 1, 2013 | 10:16 AM
KAHBOOM's Avatar
KAHBOOM
That is a totally inaccurate statement. Have you ever used it? I doubt so since you are referring to it as such.
Its used as a mild compound which can be used to remove oxidation safely without scratching the surface. It's actually not really considered a a compound but rather a polish...
Then you can wax once the impurities are removed.
There are different variants of Menzerna's polish increasing in abrasiveness (i.e super intensive polish)
Old Jul 1, 2013 | 05:15 PM
Garz's Avatar
Garz
I tried using expel headlight protectors awhile back. These were not easy to work with. They were thick and probably needed quite a bit of heat to become workable. Also, these headlights aren't exactly a flat surface. I failed miserably. Luckily they let me return them. If you must do it, definitely have someone who knows what they are doing.
I had no problem getting the thinner husky headlight protectors on my much flatter surface tundra headlights.
Old Jul 2, 2013 | 01:34 PM
antiderivativez's Avatar
antiderivativez
you can also try taking off the headlights and painting them!
Last edited by antiderivativez; Jul 2, 2013 at 01:37 PM. Reason: not sure how to post img from FB
Old Jul 2, 2013 | 01:57 PM
Kevalteam's Avatar
Kevalteam
one more for painting the headlights(inside)~~~ PM RaulG on here or I have a local guy who does it. And upgrade to TSX clear lenses if you are going to open your headlights!
RYs06MT
Apr 22, 2016 11:00 AM
kavcheung
Jan 22, 2016 02:40 PM
Upscale Speed
Oct 9, 2015 01:42 PM
