Replacing Interior lights with LED
Old Apr 1, 2013 | 04:31 PM
newspider4re's Avatar
newspider4re
Does anyone know the recommended way to open up the overhead light compartment so that I can replace the lights with new LED's? I tried prying it down but didn't want to break it.
TIA
Old Apr 2, 2013 | 07:54 AM
Scotch's Avatar
Scotch
TIA
i used a knife and pry it open.. its pretty easy
Old Apr 2, 2013 | 08:07 AM
newspider4re
does the whole piece come down (lights, button for the door lights etc)?
Old Apr 25, 2013 | 03:41 PM
Cyril Lim's Avatar
Cyril Lim
Yes it does. I used my fingers to pry it open though.
Pry from side closest to front windshield. On the opposite side are plastic catches that are non-bendable. Unclip both wire connectors.
Old Apr 29, 2013 | 10:24 AM
newspider4re
Appreciate it. Although, to replace just the bulbs i found that all you need to do is carfully remove the white covers that you press to turn the lights on. I used a small screw driver with a piece of cloth tape wrapped around it inserted into one of the edges. With a little downward pressure it will release from the unit so that you can access the old incandescent bulbs (make sure you do this with the door closed because those suckers can get pretty hot!)
I replaced all the bulbs in the car including the trunk bulb and I have to say it looks pretty slick. It definitely brightens the car up as well. It also ties in nicely with the illuminated kick plates I had installed ($232 + free labor due to a "we owe" credit from time of purchase.)
Old Apr 29, 2013 | 10:31 AM
colnajoe's Avatar
colnajoe
What LED's are you using and where did you get them from? How much per bulb?
Old Apr 29, 2013 | 11:10 AM
newspider4re
Infiniti G37 White Interior LED Package (7 Pieces) : Amazon.com : Automotive Infiniti G37 White Interior LED Package (7 Pieces) : Amazon.com : Automotive
Under $20
One weird thing I remember from the install is that they have to be installed in a specific direction. If they don't light up just flip them and they'll work.
Old May 9, 2013 | 02:58 PM
colnajoe's Avatar
colnajoe
Just got them, and put them in. I sacraficed the trunk light and swaped out my door lamps instead. Got two extra torpedo bulbs for the domes I wont use. They look great! Thanks for the inside scoup!!
Old May 9, 2013 | 03:02 PM
msking's Avatar
msking
That's cool! I installed these LEDs the other day. Check em out!
superjoey
31
Mar 22, 2023 11:56 PM
Ricio1991
12
Apr 21, 2022 01:39 PM
Thedbarz
33
Feb 9, 2016 12:05 AM
bikerjosh
Aug 19, 2015 11:26 PM
