HID Control Modules?
Old Jan 7, 2013 | 12:50 PM
ffpjlw's Avatar
ffpjlw
I just purchased my 2008 Infinti G37 Coupe a month ago. Both of my brights went out the other day so I took it to a mechanic(warranty is expired). He says that both HID control modules are bad and that both headlight assemblies need to be replaced as well. A total of $2600! Any help would be appreciated.
JW
Old Jan 7, 2013 | 10:46 PM
Weiboy718's Avatar
Weiboy718
JW
Both of your BRIGHTS? Or did you mean main headlight beams? Does everything else works? No, you shouldn't have to get new headlights and whoever is telling you that doesn't seem like he know's how to troubleshoot issues like this.
#1: Check headlight bulbs
#2: Check fuse
#3: Check ballast
Where are you located?
Old Jan 8, 2013 | 01:08 AM
unknowndesi's Avatar
unknowndesi
Just like weiboy said, check your bulbs, have a look in the DIY section on how to replace the head light bulbs. The fuse box for the lights is located behind the battery and the ballasts are located underneath the actual headlight assembly(you will have to take the bumper off and remove the headlights them self. If you do some research you can find identical ballasts for less than $100. I had significant moisture buildup and that caused one of the ballast to short out. I simply searched the web for new and used ballasts and found a used ballast off of a 350z for $30 and swapped it all out.
Old Jan 8, 2013 | 09:18 PM
ffpjlw's Avatar
ffpjlw
Thanks to both of you!!! I'll do some homework and start with the fuses first then if i need to get behind the front end and check out the ballasts.
Much appreciated fellas!!!!!
Old Jan 9, 2013 | 06:17 AM
Igor911's Avatar
Igor911
out of curiosity...did u purchase a platinum graphite coupe?
timc00k
Feb 15, 2017 09:15 AM
2K1 6T8
Oct 6, 2015 07:40 PM
Landshark
Sep 29, 2015 11:20 PM
MrRiv
Sep 29, 2015 04:59 PM
halfbreedcuban
Sep 27, 2015 08:58 AM
