Those with Dyode Dynamis LED Bulbs (Help me with Stage 2 or 3)
Old Jun 26, 2012 | 06:05 PM
sniper27's Avatar
sniper27
I assume CHLUTZ214 has a coupe. For the sedan, you do not need to remove the whole light to get to the reverse light. Just open your trunk. Take off the plastic handle inside the trunk where you grab onto to close it. you can pry it off with a flat head screwdriver. Take off about 3 clips on each side using the flat head screwdriver. peel back the carpet trunk liner and you will see the housing for the reverse light. twist the harness and remove. pull the bulb out and replace with LED. put everything back in reverse order. done. I can do each side in about 3 minutes.
Old Jun 27, 2012 | 06:25 PM
2009G37Bandit's Avatar
2009G37Bandit
Got My Diode Dynamic Bulbs today! Ordered Sunday and came to Texas Wednesday! 3 days! Fast!
Can't wait to install them. Looks like several are boards with double stick 3M Tape (with 6 lights on each board), then there ar some individual bulbs and I also ordered the back up Pair.
I am not sure which one is which, but I am sure it says somewhere on the bulbs. haven't took them out of the package yet.
Thanks
Gary
Old Jun 29, 2012 | 09:38 PM
TwoThree's Avatar
TwoThree
Looking forward to pics as I am planning on doing the swap soon. Really want to do LED turn signals front and rear but worried about the right was of them in the daytime. Most of the bulbs I have ordered from diode have been great with the exception of one running light in my headlight. One LED flickers or just stays off. Just havent wanted to send it back, wait for a replacement and do the install again as you have to remove the front wheel.
Old Jun 30, 2012 | 01:19 AM
Diode Dynamics's Avatar
Diode Dynamics
Send us an email... you usually don't need to return to get warranty service.
Old Jul 1, 2012 | 02:16 AM
TwoThree's Avatar
TwoThree
Will do! Thanks for the support.
Old Jul 4, 2012 | 11:42 PM
toobitz22's Avatar
toobitz22
can't wait for mine to come in. Probably a n00b question, but I haven't really looked too hard. The dome/map lights seem like they would be difficult to get out without messing up the plastic with a screwdriver to pry it out.
Does anyone have a DIY that the search function couldn't find for me??
Old Jul 4, 2012 | 11:53 PM
2009G37Bandit
Its easy, carefully pry it out with a screwdriver (flat head) a small one, its easy! A monkey could do it!
Old Jul 4, 2012 | 11:58 PM
toobitz22's Avatar
toobitz22
Sort of what I figured, just wanted to be cautious. It's like I brought home a new baby! Can't imagine what will happen if I put the first scratch on it
Old Jul 5, 2012 | 09:04 AM
daren_ipl's Avatar
daren_ipl
I installed my stage 3 witin 20 minutes lol better than stock bulbs and alot brighter. Only issue I had was I broke a tiny clip on the vanity mirror to get the cover off to access the bulb. Other than that adds a great look. My question is what HID color would match the led stage 3 ?????? If I were to guess I say 8k
Old Jul 18, 2012 | 01:02 PM
Tonewheel's Avatar
Tonewheel
Upgraded with the DD kit. Everything looks great, but as others have said, the double sided tape they use for the map lights is suspect, and mine gave way after a few days. I prepped well, cleaning the mating plastic with a Q-tip and alcohol...and they still failed.
I went to Autozone and picked up a roll of 3M Super Strong Automotive Attachment Tape. This stuff is used to reattach trunk logos, emblems, etc., and I found it to be super strong. Don't touch the exposed tape to the plastic until you're ready to position it...it's not forgiving!
So far, so good. We'll see if this turns out to be a permanent solution.
timc00k
Feb 15, 2017 09:15 AM
stevo4756
Oct 9, 2015 01:54 AM
halfbreedcuban
Sep 27, 2015 08:58 AM
