easiest way to swap my hid bulbs?
Exactly. Pull the front wheels and pull out the wheel well liner by removing the push clips. It doesn't have to come all the way out, you can pull it downwards, just giving you enough clearance to the back of the light.
That's the screw you have to remove to change them. No way around it.
BTW, do NOT drop it down into the headlight housing or you are screwed 6 ways to Sunday. A strong magnetic tipped #2 Philips screwdriver is your friend.
Anyone know a part number for those push clips? I need to get some.
ok so im done with one side lol and it got dark =[ that **** is a PITA with my big fingers holy ****. i was so scare i was gonna drop the screw in the housing lol.. anyways 1 osram cbi installed one to go !
I think they're referring to the one philips screw. But I don't get it either...all you have to do is push the clip together to unhook it right? I also have a 2011 like you and I don't remember seeing all those red wires in my housing lol
+1 to unhooking the hook. also when i did my headlights i took off front bumper and took the whole headlight out, much easier than trying to get it done through the wheel well. If you look in the DIY section there is a post on how to remove the headlights.
ck1109
Oct 15, 2015 11:06 PM
stevo4756
Oct 9, 2015 01:54 AM
