Drivers side window goes down, but not up??
Old Mar 31, 2012 | 07:40 PM
ayarj12's Avatar
ayarj12
Hey guys.
My drivers side window goes down when you open the door, but it doesn't go back up. If I open and close the door multiple times, the window will end up all the way down.
I went today to get some work done on the car (it came without rearview camera, so I had one installed on the rear license plate frame) and they had to disconnect the battery. Does that have to do with the problem or no? The window worked fine for a
couple hours but now doesn't go up.
Any ideas?
Old Mar 31, 2012 | 07:44 PM
ShyAznB8oi's Avatar
ShyAznB8oi
I wish I was on my laptop right now, i can help you out lol. Go look on the "diy" section.. There should be a window fix thing..
Or go in your car,
Old Mar 31, 2012 | 07:47 PM
Weiboy718's Avatar
Weiboy718
Do the window reset procedure
Old Mar 31, 2012 | 07:54 PM
mindawg's Avatar
mindawg
sometimes window tint will cause those issues as well
Old Mar 31, 2012 | 08:18 PM
ShyAznB8oi's Avatar
ShyAznB8oi
You will need to reset your windows since your battery has been disconnected. To perform a window reset:
1. Push the ignition switch to the ON position.
2. Close the door.
3. Open the window more than halfway by operating the power window switch.
4. Pull the power window switch and hold it to close the window, and then hold the switch more than 3 seconds after the window is
closed completely.
5. Release the power window switch. Operate the window by the automatic function to confirm the initialization is complete.
6. Perform steps 2 through 5 above for other windows.
From BlackBettys Ground Thread
Old Mar 31, 2012 | 08:19 PM
ayarj12's Avatar
ayarj12
Originally Posted by ayarj12
Hey guys.
Any ideas?
EDIT: PROBLEM IS FIXED. Just needed a window reset. Thanks everyone for the help! Mods feel free to lock this if you want.
Gefartenblatz
Nov 10, 2015 11:45 AM
Raleclair
Oct 8, 2015 02:06 PM
nbast
Sep 14, 2015 12:39 PM
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
Falker11
Sep 9, 2015 08:53 PM
