Help Moisture in headlights
Old Jan 25, 2012 | 09:36 PM
SwissCheeseHead's Avatar
SwissCheeseHead
I installed some HID fog lights about a week and a half ago. I had to drill a 1 inch hole in the back of the fog light cover in order to run the wiring through. The provided rubber grommet was pretty flimsy and tore on me as I was trying to get it into the new hole that I had to drill. It's freezing and dry here so I thought I could just put duct tape over the hole until I could do a more permanent fix. So now I have moisture inside my headlights. How can I dry them out before I repair the modified cover?? Would a hairdryer work? I was thinking of using JB weld to fill the hole around the wires...should I use something else? JB weld is supposed to be waterproof.
Old Jan 25, 2012 | 10:27 PM
Modme's Avatar
Modme
Use black silicone. It's more flexible. JB weld is too rigid.
Old Jan 25, 2012 | 11:43 PM
QtrSkill's Avatar
QtrSkill
Im not sure if you can dry it up with hairdryer.. but give it a try on cool air..you dont want to melt anything. if no results well you just going to have to do it the hard way open them up and clean but make sure you use new sealant
Old Jan 26, 2012 | 12:17 AM
JDUB916's Avatar
JDUB916
I had that prob once, yes I used a hair dryer and it took a long time. Good luck. Oh and I agree on the silicone Jb weld is too stiff and will prob crack
Old Jan 26, 2012 | 10:43 AM
SwissCheeseHead
Got it...the hole is a 1" hole though. How am I gonna fill that up with silicone? Do they make like a silicon putty? I figure the original case was a hard plastic...so JB weld putty would be rigid enough to hold shape enough to dry and keep water out.
I don't think JB weld will crack since it's a cold weld product...
If I were to take the headlight apart...I might as well paint it too
Old Jan 26, 2012 | 01:46 PM
Weiboy718's Avatar
Weiboy718
Damn! 1" hole is huge. You should've cut the hid bulb wires then drill 2 small holes on the cap according to the size of the wires then connect them back via disconnects instead after sliding the wires thru the hole
Old Jan 26, 2012 | 01:52 PM
JDUB916's Avatar
JDUB916
I agree! Your concern should be how to fill that big of a hole, I always cut my wires and reroute them to minimize cutting. Good luck
Old Jan 26, 2012 | 03:29 PM
breftayka's Avatar
breftayka
Wise words are wise.
Old Jan 26, 2012 | 03:47 PM
Weiboy718's Avatar
Weiboy718
Lol! I'll never give failure advices.
Old Jan 26, 2012 | 10:31 PM
SwissCheeseHead
i know...I should have thought about it before I did it. That's what the instructions said...so I did it. I will learn for next time
I figure if I run the hair dryer inside the headlight long enough, that it'll dry out. I'll run it on a low heat setting so I don't ruin anything. I figure the bulb gets way hotter than a hair dryer would anyway. I was going to use some JB weld putty to make a pancake and slap it on top of the hole, then route wires through while it was still pliable.
Do they sell replacement covers?? That might be an option if I can find some. Anyone selling theirs? lol
Old Jan 26, 2012 | 11:12 PM
msmching's Avatar
msmching
did u ask the dealer if they are selling it? I will guess so tho.
btw, even if you turn on to high speed HOT hair dryer, its not going to melt it lol. People have been placing theirs into the oven to open it up at high degree. @@
try to use as much time if you are to use the hair dryer... because opening up and cleaning the inside lense, you may scratch it a little. (They are pretty sensitive to the towels you use)..
Old Jan 27, 2012 | 10:50 AM
SwissCheeseHead
True!
I'm probably going to spend ALL day Sunday taking care of them. Putting in the HID fogs was not worth it. The ballast was buzzing and wouldn't turn on sometimes...kinda scared me so I'm taking it out all together and going with a straight halogen. Urgh. Lessons learned.
Old Jan 27, 2012 | 12:30 PM
Weiboy718's Avatar
Weiboy718
Weird! I never had any issues with mines or any other ones that I installed on people's car. Which ones did you buy?
I may have a pair of the fog light covers laying around at home. I'll check tomorrow and let you know.
Old Jan 27, 2012 | 01:57 PM
Modme's Avatar
Modme
I think the difference is you don't leave a 1 inch hole in the back of the housing. =p
Old Jan 27, 2012 | 02:03 PM
SwissCheeseHead
I bought the HID fog light conversion kit from Diode Dynamics. I would recommend their interior lights but would recommend staying away from the exterior stuff.
If you have new covers, that'd be awesome!! Let me know ASAP cuz I'll be changing out my lights this weekend but will wait until the covers come (if you have them).
