Change halogen fog light to brighter white fogs?
Old Jan 17, 2012 | 03:38 AM
Rickyay's Avatar
Rickyay
Anyone know what kind of bulb i can use to make the fogs a bright white color instead of that yellow stock halogen color? Brand name? LEDs?? Im clueless. It is a 2010 G Sedan.
*im not going to bother with a HID conversion*
Old Jan 17, 2012 | 09:43 AM
sniper27's Avatar
sniper27
just get some of those blue coated bulbs for the "hid" look. you will loose some light output, but if you're only concerned for the look, then that'll do. If you want a good compromise of a little whiter color without loosing too much light output, get some Sylvania Silverstars. Or PIAA if you want to spend twice the $
Old Jan 17, 2012 | 12:07 PM
JDUB916's Avatar
JDUB916
Depends on what year you have, etc. Different bulbs for different years, however check out Diode Dynamics. They have LED bulb replacements for fog lights in a pure white (And I was told yellow LED fog lights are in the works and should be available in February). Find your bulb here: Foglight/DRL Sizes - Listed by Size - LED Bulbs
Of you could order some other style bulbs. I just ordered the PIAA Plasma ION yellow fog lights for my 2012 G37 Sedan. Those fog light bulbs are H8
Good Luck!
Old Jan 17, 2012 | 01:32 PM
Diode Dynamics's Avatar
Diode Dynamics
What year/model do you drive?
Old Jan 17, 2012 | 05:29 PM
Rickyay's Avatar
Rickyay
Its a 2010 sedan tnx in advance
Old Jan 17, 2012 | 05:55 PM
TVPostSound's Avatar
TVPostSound
PIAA makes 4000K Halogens in H11.
They will far outlast LEDs. (I gave up on LEDs!!)
http://i1089.photobucket.com/albums/...g?t=1326763054
Old Jan 17, 2012 | 05:58 PM
TVPostSound
http://www.amazon.com/15211-Style-Xt...6841090&sr=8-1
Old Jan 17, 2012 | 06:01 PM
sniper27's Avatar
sniper27
he needs H8 for 2010 sedan.
Old Jan 31, 2012 | 10:27 PM
nlavi8's Avatar
nlavi8
Would these fit on a 2011 G37 Sedan Journey foglight?
Old Feb 1, 2012 | 12:18 AM
Infiniti7's Avatar
Infiniti7
what is the purpose of yellow fog lights? how would they look with bright/blueish HID lights.i would think the yellow and blue wouldnt go
Rickyay's Avatar
Rickyay
H11 is for coupes, you need a H8 for the sedans.
Old Feb 1, 2012 | 12:50 AM
With yellow fog lights you can actually see in fog. All of the HID stuff and blue colored bulbs people put there are mostly useless to actually illuminate the ground in bad weather, it's just for looks and to throw glare at other drivers.
Old Mar 31, 2012 | 11:20 PM
noloveg37's Avatar
noloveg37
is there/what is the replacement bulb for a stronger yellow hue on the fogs?
Old Aug 19, 2013 | 02:25 PM
jefftodd's Avatar
jefftodd
anyone know what (fog) bulbs i would need for a 2010 anniversary coupe? TIA
Old May 28, 2016 | 07:46 PM
fengyink's Avatar
fengyink
You need H8.
