LED Light kit
Old Oct 21, 2011 | 06:56 PM
vmfldis's Avatar
vmfldis
LED Light kit
I installed Stage 2 LED kit from Diode Dynamics. But I just noticed(dark) when the lights are off I can still see very tiny of glowing from the map light. I haven't got chance to check the other lights but I'm worried if this will drain all the battery out. Is this normal for LED kits? What should I do?
Old Oct 21, 2011 | 10:39 PM
rks's Avatar
rks
it's normal for LEDs but I have the Stage 3 and I don't seem to notice it.
Old Oct 21, 2011 | 11:06 PM
vmfldis's Avatar
vmfldis
so its normal for all LED kits out there?
Old Oct 23, 2011 | 09:56 AM
2008G-Man's Avatar
2008G-Man
No ... some are worse than others. I have VLED and I don't notice mine on (They might be but so faint you can't see it) and far as being worried about voltage draw, don't. I would take years for a LED to drain a battery.
Old Oct 23, 2011 | 10:27 PM
vmfldis's Avatar
vmfldis
bump, anyone else got a clear answer?
Old Oct 24, 2011 | 12:16 PM
Diode Dynamics's Avatar
Diode Dynamics
This is completely normal for LEDs, due to the lower resistance of the bulb. With a dimmer, there is a tiny amount of power left over, and it is not enough to light up your stock bulb. But since LEDs use much less power, they may light up a little bit. It completely depends on the grounding efficiency of your particular vehicle. It will not affect your vehicle in any way, since this is usually just lost power.
Old Oct 24, 2011 | 12:33 PM
vmfldis's Avatar
vmfldis
Great! thank you so much for the clear answer!
superjoey
31
Mar 22, 2023 11:56 PM
Ricio1991
12
Apr 21, 2022 01:39 PM
Thedbarz
33
Feb 9, 2016 12:05 AM
Upscale Speed
Aug 6, 2015 04:08 PM
