HID xenon headlights slightly shake?
Old Sep 19, 2011 | 11:44 AM
skiingj's Avatar
skiingj
Question HID xenon headlights slight shake?
I’ve done a search and couldn’t find anything. Should my HID xenon headlights slightly shake when going over rough roads? Not sure if it’s both headlights but at least one is slightly shaking/vibrating over rough road. Never had HID’s before, not sure if this is normal? Thanks!
2011 G37S Coupe Prem, Nav, Sport
Old Sep 20, 2011 | 09:28 AM
Swacer's Avatar
Swacer
It shouldn't. The car should have an auto leveling sensor in the rear end. Check your head lights, if there are 2 plugs going into the head light (with one in particular going to the HID), that should be the auto leveling plug.
If you have that (My Genesis Coupe has one, so I"m not too sure on the G at the moment until I get mine), and they are still moving around, I would take it to the dealer and that addressed.
Old Sep 20, 2011 | 09:35 AM
breftayka's Avatar
breftayka
Do you have the technology package?
Edit: Nevermind no more adaptive headlights in 2010-11... If you go over a bump it will do like any other car.
Old Sep 20, 2011 | 09:54 AM
ANMVQ's Avatar
ANMVQ
I have never seen mine or my wifes shake? Sounds like the bulbs are loose, Have you changed them or adjusting anything up front.
Old Sep 20, 2011 | 11:04 AM
Presto's Avatar
Presto
I have afs and mine do shake a bit.
Old Sep 20, 2011 | 11:06 AM
skiingj's Avatar
skiingj
Thanks for the replies. I have not changed/touched a thing. I'm far from mechanical. I'll have the dealer check it out at the 3k oil change.
Thanks!!!
Italia311
Jun 28, 2016 11:25 PM
conkus805
ECU Tuning / Dyno Data
46
Nov 19, 2015 07:49 PM
2K1 6T8
Oct 6, 2015 07:40 PM
halfbreedcuban
Sep 27, 2015 08:58 AM
VQCrew
Sep 26, 2015 01:19 PM
