Heavy Rainstorm last night. Passenger side flooded in a coupe?
Old Jun 21, 2011 | 12:41 PM
Viper62382's Avatar
Viper62382
Exclamation Heavy Rainstorm last night. Passenger side flooded in a coupe?
Ive had trinkles of water come in occasionally before, but this morning when I got into my car, and turned my a/c on I could hear the fans sloshing around water. Then I looked over and low and behold beneath the glove box the panel that clips underneath had come off (presumably from the weight of the water). Do I have a clog somehwhere in a drain line? Someone forget to put a seal back on during a recent install? Common factory problem? HELP!
Old Jun 21, 2011 | 01:05 PM
Kidcane's Avatar
Kidcane
Florida G Club
^^Could be either. I have seen both. Have you recently put in aftermarket stereo or alarm?
Old Jun 21, 2011 | 01:07 PM
Viper62382's Avatar
Viper62382
Not recently. Only thing recent has been nitrous....but I think ive washed the car and/or rained since then and hadnt any water issues like this...
Old Jun 21, 2011 | 01:12 PM
Kidcane's Avatar
Kidcane
Florida G Club
Washing it may not get enough water to cause the issue but most likely a drain got clogged/blocked or a seal was removed/damaged during your install.
Old Jun 21, 2011 | 01:25 PM
ONEighty's Avatar
ONEighty
Check the drain by the battery cover, they get clogged often. If it's not clogged, observe the drain under the battery, pull the cover off, pull out the battery and the fuse box, make sure everything down there is clean.
Old Jun 21, 2011 | 01:29 PM
Viper62382's Avatar
Viper62382
Thank you. Will check it out.
Old Jun 21, 2011 | 08:58 PM
KPierson_'s Avatar
KPierson_
Also check to make sure if they ran any wires through the large grommet over the battery that they sealed it back up. They are waterproof for a reason!
Old Jun 21, 2011 | 10:04 PM
pcwd's Avatar
pcwd
Yep, the rubber grommet on the passenger side might be the cause if any aftermarket wire was installed.
https://www.myg37.com/forums/g37-sed...-footwell.html
superjoey
31
Mar 22, 2023 11:56 PM
SiKHG37
18
Sep 14, 2015 01:35 PM
Ricio1991
Aug 23, 2015 10:44 AM
tite_tite
Aug 22, 2015 05:21 PM
