HID fogs install question
Old Jun 18, 2011 | 02:42 PM
cjc357's Avatar
cjc357
Bought the DDM tuning HID h1 kit for my 08 coupe.
My question is with the ground wire. It seems to be soldered into the light socket. I pulled the rubber casing back but could not remove it.
Does it come off? do you just cut it and attach to HID kit? You guys just grounding the HID kit somewhere else?
Old Jun 18, 2011 | 03:09 PM
A_Palaroan's Avatar
A_Palaroan
i havnt installed mine yet this will be some good information. subscribed
Old Jun 18, 2011 | 03:34 PM
Steveo47's Avatar
Steveo47
i have the v-led kit. Its plug and play. Two wires hook to the stock fog, just unplug and replug
Old Jun 18, 2011 | 05:12 PM
cjc357's Avatar
cjc357
Mine are plug and play as well. Maybe your 2010 is different. I have two wires to connect. One wire plugs into the wire that connected directly to the OEM light bulb and the other wire is a ground wire.
the ground wire on the car seems to be soldered into the light assembly unless I am not pulling on it hard enough.
Old Jun 21, 2011 | 06:05 PM
cjc357's Avatar
cjc357
Bump
Can I just cut the ground wire and attach to balast of HID kit??
superjoey
31
Mar 22, 2023 11:56 PM
maybeg37
Sep 8, 2015 02:33 PM
bikerjosh
Aug 19, 2015 11:26 PM
