Best thing since the Iron-Man? Quad Bi-Xenon Projectors?
+1...anyway you could pm a price? Or is it too early to determine? Also, can you pm me your shop location? I THINK I work around the corner from you in coney island right now and would love to stop in and get some other quotes for work...
NOW MORE PICTURES!
NOW MORE PICTURES!
i like the second option better. for one, it looks a lot cleaner than the first one, maybe its that it sits with extra room around the sides so it gives a more OEM look. also, i like the option of having the led shroud around it, as it would match a lot of the services you guys do for the stock projectors.
Alex/Igor, any idea on how much its going to cost? even a rough estimate? i want to get an idea just so i can keep that money aside for when you guys start this service.
Also, would you eventually use the same led's that you have on the iron mans or your led orbs for these fog light projectors? reason im asking is because in the last couple pictures you posted, the sedan taillight leds seemed way too large compared to the iron mans on the stock projector.
Sorry guys, we're moving to a new location within a week and are doing construction, setting up, etc. Pricing will be made as soon as we do more testing with the retrofits and calculate the time/costs. Thank you for your patience
-Alex
-Alex
Since I promised... I stayed late to get you guys some updates.
The full size morimoto projectors are much brighter, in fact they're brighter than the factory projectors, but I'm sure with some tweaking I can make the factory projector work just as well.
The projector is pretty big, so its extremely tight and there's no room for a projector shroud. I was able to retain all the plastic on the factory housing so this modification is reversible, and requires no cutting or plastic welding. The cap to cover the bulb might be a tight fit though.
The small "matchbox" projectors fit much better, and I can actually fit a projector shroud around it. To accommodate LEDs around the projector I used a plastic bezel out of the Sedan taillight and trimmed it to fit the housing. This is only a prototype, and if there's enough interest, we would consider mass producing the shrouds in high temperature plastic. It would obviously fit and flow much better with the housing and cover any gaps or holes.
The camera died and I didn't get a chance to snap more pictures, but the projector is very bright as well, it's not as wide as the larger projectors, but the output is great. I'll try to snap some more pics.
The true brightness will be tested when I get a car to mount these on and light up the streets.
