Best thing since the Iron-Man? Quad Bi-Xenon Projectors?
Do you guys mainly want this for aesthetic purpose, using a SLIGHTLY smaller projector will barely diminish the output but still function 100x better than the factory fogs, but not as well as the factory projector, probably about 40% less output.
+100000000000000000
+100000000000000000
id rather have the smaller projectors and have the option for iron mans rather than full sized projectors and have nothing for them, but thats just me. i dont have fogs right now and its not been a problem so anything is better than the nothing i have now lol
I'd rather go with 2 full sizes. I can use all the light output I can get. Deer suck!
What if we went with 2 full projectors - would it be double the brightness? And then install fogs in the bumper for the low visibility.
These babies just came in... and holy ****, I doubt we'll even need 2 full size projectors, these things are bright as shyt ! The cut off is soo sharp, it's not as wide as the OEM, but its just as bright. Trying to found out the deal on the projector shrouds since these projectors produce so much heat, we'll need to use the same high heat plastic that's used on OEM shrouds to prevent it from melting.
