Q for those who have load resistors in their LED turns
Old May 26, 2011 | 03:23 PM
Damn Dirty Ape's Avatar
Damn Dirty Ape
Sooooo I'm using the 45led LED module in both rear turns. I've hooked on a 6ohm load resistor on each rear LED unit. On the 4-ways I get normal flash, but on a left or right signal I get hyperflash (even with the 6ohms installed).
Isn't this all there is to the load resistor install?
Old May 26, 2011 | 03:38 PM
DustinEarnhardt's Avatar
DustinEarnhardt
Have you verified you're connected to the right wires? A load resistor is supposed to be wired across a bulb, not in series with it.
In other words, if you have a red wire and a black wire going into the bulb, one end of the load resistor should be connected to the end of the red wire before the bulb and the other end should be connected to the end of the black wire after the bulb.
Sounds like its not hooked up properly. The reason it works with the hazards is because there's enough load being drawn from the two front bulbs that its not messing with the flasher.
Old May 26, 2011 | 04:11 PM
Damn Dirty Ape
On the rears I have a green and a black going to the socket. I have one wire from the LR going to the green, and one wire from the LR going to the black. Correct?
Old May 27, 2011 | 09:36 AM
CDONNS's Avatar
CDONNS
Yeah, that is correct. And since resistors aren't polarized it should matter the direction they're installed. A couple troubleshoots you could do (if you have the time/courage/patience):
1. Kind of obvious but why not state it, make sure you are wired into the correct bulb in the tails (turn signal).
2. If you own an ohm meter that can measure resistance, try that out and make sure your resistors aren't faulty.
3. Try hooking the resistors up to the front turn signals and see if that helps. (that is where I mounted mine, but then again I changed all 4 of my turn signals and only needed 3Ω since I had more resistance from all 4).
4. Make sure you have a clean connection between wires. How did you hook them up? ie. T-taps, simple splice and tape, solder, etc.?
5. Or just take some pics of your set up and post up so we can check it out.
Old May 27, 2011 | 09:42 AM
Damn Dirty Ape
I'll check as much as I can, I'll try to post up some pics. I used the blue taps with the silicone grease in them, pinch with the pliers. I know I'm on the right wires from what I see.
Old May 27, 2011 | 10:11 AM
CDONNS's Avatar
CDONNS
Alright, then I would say it's either A) faulty resistors (which is pretty unlikely) or B) you don't have a clean connection with the taps (I would focus more on this).
Old May 27, 2011 | 11:40 AM
DustinEarnhardt
The purpose of the load resistors isn't to simulate resistance, its to simulate load. You say you bought 6 ohm resistors, but what is the current draw rating? It should have a wattage rating too. (i.e. 6 ohm / 10 watt) If you ended up with a very low wattage resistor, it could be that the flasher unit is still thinking that there's a burnt out bulb since no power is being drawn through the circuit.
Old May 27, 2011 | 03:00 PM
Damn Dirty Ape
Ha-ha crappy cheap blue plastic taps weren't even piercing the wires. They work fine now.
Thanks to those who replied.
Old May 27, 2011 | 03:14 PM
Damn Dirty Ape
Diode Dynamics
Lighting/Cleaning Products
81
Nov 30, 2021 02:28 PM
MEH2013G37
Sep 24, 2015 08:37 AM
CasperG37
Sep 14, 2015 07:46 PM
New2Infinity
Sep 9, 2015 10:34 AM
pauliewalnutzz
Sep 8, 2015 11:41 AM
