Question about Water Leak on Passenger window
Hi All,
I have water dripping in on the passenger side by the tweeter like some of the other threads i've seen here. My front windshield was replaced in the summer, Just wondering if water is coming in because of the front windshield. Dealer said that if the front windshield was replaced that is the reason.
Thanks
Thanks
if water is on your tweater, water is coming in from the window not the windshield. first look to see if your window rubber is cracking or inflexible. then do the reset of the automatic window adjustment. this should fix the leak.
Thanks, I will have to check the window rubber, I already tried the window adjustment once before.
Tried reseting the window but did not help, Have an appointment with the dealer next thursday to have them look at it.
This was thursday while I was driving to work on the Drivers side
And this was today on the passenger side, I went out to see if it was dry, apparently not!!!
I hope they can fix this. Like I said before my Front window was replaced but that was back in August and this started happening in December.
Other then this, I still love the car.
Two suggestions: Change dealer if he said so and ask another dealer to adjust your windows. This is known issue with G coupe since long ago and happened even to Z coupe owners too. Happened to me too in first heavy rain after I got my car. Nothing to do with windshield.
If adjustments doesn't help, than ... Not sure if anything else actually helped reading other posts about, sorry.
Thanks Guys, I will update after I go there on Thursday and if they give me trouble I will go to the another dealer. Last time I mentioned it to the service advisor that I usually don't deal with since I was picking up the loaner at 4pm. (My regular one was gone for the day). The car was in for wind noise last time and they replaced the small rear passenger window.
Tell him there is service bulletin he needs to check in his computer about, adjustments helped me but honestly I didn't drive in very heavy rain after. Regular or light rain is OK now.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com
ffice
ffice" /><o
></o
OK thanks again Breitling, I will mention it to him.
I had this happen to my drivers side window and I just took it to the dealer. They said the window was very slightly off track, so they reset it and after months of the rainy season, everything is a-okay.
Got my car back today. They readjusted and added foam padding to both sides and couldn't get it to leak again. Hopefully it will stay dry.
They also fixed a slow leak in my front tire, There was a small nail in it.
While I was there, I had them install the ambient lighting kit that i received.
Very impressed with the communication from the tech. He actually called me yesterday to ask me about the leak before he started to troubleshoot and then called me today and explained what he did.
