LED reverse light question
Old Jan 11, 2011 | 02:37 AM
jhenka's Avatar
jhenka
Lightbulb LED reverse light question
Just to give you guys some quick background info.
I have changed out every bulb in my car for either hid or leds, everything from my glove box to my rear turn signals in taillights. The only light that has given me issues is the reverse light i have yet to find a bulb that is brighter than the stock bulb. Sure the leds may SEEM brighter when looking directly at it but when using the back up cam nothing comes close to the stock halogen bulb.
You guys have any links or names of bulbs that you would think would work?
I know that it is T10/ T15 led bulb and the housing is fairly heat resistant up to 165 degrees i believe.
Old Jan 11, 2011 | 03:22 AM
maxfinity's Avatar
maxfinity
+1 my reverse Led lights look bright but the light output sucks. Btw, what bulbs did you use for your rear turn signals?
Old Jan 11, 2011 | 03:41 AM
roots4x's Avatar
roots4x
You should do an HID coversion for the reverse lamp.
EDIT: I'm just kidding, but I'd be very impressed if you did.
Old Jan 11, 2011 | 03:47 AM
maxfinity's Avatar
maxfinity
Is that even possible?
Old Jan 11, 2011 | 09:01 AM
EnviedG35's Avatar
EnviedG35
A friend of mine owns a headlight modification company and owns his own HID brand. I asked him over a year ago to make a hid reverse lamp haha......needless to say it never happened.
Old Jan 11, 2011 | 10:34 AM
jhenka's Avatar
jhenka
I have a partnership with an HID company which pretty much means an unlimited supply to hid and i have tried retro fitting hids into the tails, hence the way i found out their heat resistance. LOL I tried everything from a 55 watt to a 25 watt (Gunna be big just you wait and see) the 25 watt lasted the longest i left it overnight and the damage was minimal, as soon as im able to protect from the heat i will let you guys in on it =)
The lights i used for my tails are from my distributor but these are the same exact ones.
2 WHITE 6K V-LEDS 7W HIGH POWER 20 LED BACK-UP LIGHT BULBS 7440 7443
Old Jan 11, 2011 | 10:37 AM
EnviedG35's Avatar
EnviedG35
A 25 watt would be perfect for the reverse lamps. I know on my reverse housing there is actually a vent on them....and the back up lights are on for such a short period of time i dont think heat would be much of an issue. The only thing you would have to do is make a wiring harness with a direct connection to the battery and switched power from the reverse lights.
Old Jan 11, 2011 | 10:38 AM
TheIvoryG's Avatar
TheIvoryG
HID reverse lights? Really? What is this world coming to?
I want some.
Old Jan 11, 2011 | 10:43 AM
lzzhang10's Avatar
lzzhang10
I have those and I thought they were "bright" enough. At least I have no problem seeing anything from the back-up camera, nor did I have problem with the stock bulb. It just looks a lot better now.
Maybe they are not technically brighter..but they do give the street more contrast when u view it from the camera.
Old Jan 11, 2011 | 12:23 PM
jhenka's Avatar
jhenka
Don't worry i have the wiring kit already made just ironing out the kinks for the heat problems as mentioned above.
I want some.
They will be made available around March /April.
Once released they will be available in 2 setups and In virtually any color.
Setup 1 comes with the wiring kit, which wires directly to the battery. (people with subs, after market systems, etc will need this)
setup 2 comes with a direct connections simply plug hide and play.
Old Jan 11, 2011 | 12:43 PM
lzzhang10's Avatar
lzzhang10
Doesn't HID needs time to warm up anyway? by the time it warms up...it prolly will be turned off already.
Old Jan 11, 2011 | 12:58 PM
godzilla619's Avatar
godzilla619
V-LEDS HIGH POWER 18W LED BACK-UP LIGHT LICENSE PLATE FRAME
If you want a brighter light for when backing up i suggest you get this vleds license plate bracket. I have it on my car with medium tint on the rear window as well as tint on my rear tailights. As we all know its hard to see what is behind us in our cars at night so with the tint i was reversing almost blind. Therefore i gave this a try. The lights on this frame are amazing. Lights up everything behind you with an intense white/blue light, so much so i can see objects through the rear windo and not just using the camera. Install is pretty easy too. Takes only about 30 minutes.
Old Jan 11, 2011 | 01:02 PM
Kidcane's Avatar
Kidcane
Florida G Club
Yeah I changed out my reverse lights with the Super Bright LEDs like the ones from VLeds posted above and they definitely are not bright enough but I also changed out my license plate bulbs and those give off plenty of light where I can actually see with them through my reverse cam.
Old Jan 11, 2011 | 02:03 PM
jhenka's Avatar
jhenka
they get bright enough within seconds. So figure you throw it in reverse by the time you count to 5 they are already at max brightness.
The reason why i decided to do the Hids i have 5% all around and backin up / parking on street with no street lamps is impossible.
Old Jan 11, 2011 | 02:58 PM
roots4x's Avatar
roots4x
Wow, I can't believe that it's actually gonna happen (HID backup light). I will probably pass, but that's pretty cool.
