Need help please! Fog HID conversion
Old Sep 18, 2010 | 12:30 PM
anacondatp's Avatar
anacondatp
I read a couple of threads on how to do fog HID conversion and decided to do it for my 08 G37 coupe. It is a major PITA to do this so I really respect all the people who have finished this. It is almost finished but now I have a problem, the fog won't turn on. While I was doing it, I tested and everything worked like a charm. Even after putting the bulb in place, I tested a second time and everything was still working. Now after I zip-tied the ballast and the wire in place, the fog will not turn on and I have no idea what I did wrong.
Please suggest me as to where I should start to diagnosis the problem. Do you think I blow any fuse? Is the fog fuse in the IPDM box?
Now I did not know that the fog wattage is 55W so I purchased the 35W kit from DDM Tuning. Could that be the problem? Does anyone know if I can use the 35W ballast or it has to be 55W ballast?
Please help me out guys. Thank you so much
Old Sep 18, 2010 | 12:40 PM
speedracer g37's Avatar
speedracer g37
Almost all hid kits are 35w. You may have pulled a connection when you zip tied the wires down or may have blown a fuse. Check the owners manual for the fuse location and check the fuse. If both fogs are not coming on, that's most likely what happened.
Old Sep 18, 2010 | 01:02 PM
anacondatp's Avatar
anacondatp
Thanks for your quick reply speedracer, yeh, i found the fuse and i think i blew it. is there extra fuse inside the car or do i have to buy it at an auto part shop? i remember reading somewhere in the manual that there is extra fuse in the car. anyone knows?
Old Sep 18, 2010 | 01:53 PM
anacondatp's Avatar
anacondatp
Nvm, im gonna answer my own question in case other people do not know. There is a fuse puller and 3 extra fuse, 10,15,20amp in the kick box on driver side left foot (next to the dead pedal)
Old Sep 19, 2010 | 12:49 PM
Clutchr6's Avatar
Clutchr6
where did you find the fuse?? I was not able to find it on my 2010
Old Sep 19, 2010 | 01:02 PM
anacondatp's Avatar
anacondatp
fuse puller is in top right corner. spare fuses are at bottom left corner labelled SPARE
Old Sep 19, 2010 | 01:33 PM
hispeed-lowdrag's Avatar
hispeed-lowdrag
The coupes are all 55W and the sedans are 35W. You can use a 35W instead of 55W but not 55W instead of 35W.
Old Sep 19, 2010 | 03:47 PM
Weiboy718's Avatar
Weiboy718
does this one has it's own relay wirings?
conkus805
ECU Tuning / Dyno Data
46
Nov 19, 2015 07:49 PM
2K1 6T8
Oct 6, 2015 07:40 PM
Landshark
Sep 29, 2015 11:20 PM
halfbreedcuban
Sep 27, 2015 08:58 AM
dlc1988
Sep 2, 2015 09:40 AM
