Plastidip Front Grille Question
Old Aug 28, 2010 | 03:44 AM
n00bfare's Avatar
n00bfare
Hey everyone, since my car is leased, i dont want to take apart anything near the engine area cuz it might become loose afterwards. I was just wondering if it is bad to just spray the grille while it is on the car. If some paint goes thru and dries, will it affect the filter behind it? Thankss =)
Old Aug 28, 2010 | 03:56 AM
RYs06MT's Avatar
RYs06MT
you'll be fine taking the grill off and painting it... screws/pins will not come loose, and on your lease return they will not be so picky about that, have some fun
Old Aug 28, 2010 | 06:01 AM
cvipgo's Avatar
cvipgo
or you can get another grill for about $120 and paint it and replace at the time you are returning the car.
Old Aug 28, 2010 | 11:22 PM
Frankyg37s's Avatar
Frankyg37s
dont plasti dip the front grill mine is plasti dip and im about to remove it cose i cant stand all that lint from anywhere there always whit flufy stuff on it i cant stand it painting it would be better but you cant undo-it thats the problem
Old Aug 29, 2010 | 02:29 AM
n00bfare's Avatar
n00bfare
ohh, that suckss. i heard that it is a pain in the *** to remove the radiator cap under the cover tho, is that true? Also, if i was to remove the cover, will i be able to change the daytime running light/foglight on my sedan?
Old Aug 29, 2010 | 02:36 AM
cvipgo's Avatar
cvipgo
true... not as easy but if you do a few times then you will learn the tricks to do it 10 minutes...
Old Aug 30, 2010 | 03:11 PM
soundmike's Avatar
soundmike
I've had mine for a while now and it's gone through torrential rains, got blasted by loose gravel on the freeway and several washes. It looks just as good as the day i sprayed it on.
Perhaps if you wipe it with cloth it catches lint? I only use MF or a Chamois to dry my car, so lint is not an issue in my case.
By the way, OP, i painted mine with the grille attached.
gshack » Quick ‘n Easy Black Grille
If you do it right you'll minimize the overspray going to the radiator. This thing sprays much differently than spray can paint.
Old Sep 5, 2010 | 05:53 AM
Infinite.G's Avatar
Infinite.G
Anybody clearcoat plasti dip? Seems like it would crack.
Old Sep 8, 2010 | 11:43 PM
sniper27's Avatar
sniper27
you can also vinyl wrap your grill.
Old Sep 9, 2010 | 03:36 PM
D_Nyholm's Avatar
D_Nyholm
So, who is selling thier grills for $120? :P
Old Sep 9, 2010 | 03:48 PM
cruzmisl's Avatar
cruzmisl
Anyone done this on a black obsidian G?
Old Sep 9, 2010 | 06:40 PM
Infinite.G's Avatar
Infinite.G
I don't like the look of the matte black on the BO... maybe if you clear coat it, but I think it would crack.
Old Sep 9, 2010 | 07:33 PM
soundmike's Avatar
soundmike
Y'all can get the Perfomix F-799 Top Coat, made specifically to go on top of Plasti-Dip.
Old Sep 10, 2010 | 12:21 AM
Infinite.G's Avatar
Infinite.G
^and it won't crack?
I bet some sort of silicon product would work good... like a clear plasti dip.
jaylock92
Apr 22, 2022 12:39 PM
G37xhibeet
Nov 15, 2016 09:29 AM
Jensen Mathew
Aug 16, 2015 08:06 PM
xpcgamer
Intake and Exhaust
Aug 4, 2015 02:18 PM
