Why does the left license plate bulb keep dimming?
Old Jun 22, 2010 | 02:01 PM
Creepers's Avatar
Creepers
So I replaced all my lights with LEDs (except the glove box biotch), and all have worked well EXCEPT the left side license plate bulb.
The first time it dimmed, I thought it was a bad bulb, so I replaced it. This time, it dimmed again in a very short period of time, so now it's a pattern.
Have any of you experienced this problem? Could it be from washing the car and spraying that area? Or maybe I should just leave the regular light in there, even though it's yellowish? Please advise.
Old Jun 22, 2010 | 02:25 PM
hispeed-lowdrag's Avatar
hispeed-lowdrag
I doubt it's from washing...otherwise everyone would experience it.
Maybe the wiring has a bad connection, that would explain why it isn't always like that. It might be a loose connection
Or the bulb might not be in the correct way/enough. try to check those two and if it's still happening then I
Old Jun 22, 2010 | 03:16 PM
myk1013's Avatar
myk1013
probably just a coincidence. Not a pattern.
Old Jun 22, 2010 | 10:41 PM
yogregb's Avatar
yogregb
Your ground wire connection is loose or corroded to that light. Bad grounds produce dim or inop lights. GL
Old Jun 22, 2010 | 10:53 PM
Creepers's Avatar
Creepers
ty, that makes sense, but why does it start off working perfectly for a few weeks, then go dim all of a sudden? twice? shouldnt the 2nd time i replaced it have gone dim from the get-go?
idk...
Old Jun 22, 2010 | 10:55 PM
Creepers's Avatar
Creepers
ill check the connection tomorrow. as far as the wash, i use the coin self-wash spray, which is super powerful, and shoot into the license plate area. but now that i think about it, if the water got to it, it probably would go out and not dim.
ANMVQ
Dec 8, 2016 04:55 PM
bigmike35nj
Sep 22, 2015 12:49 PM
CasperG37
Sep 14, 2015 07:46 PM
B Feelgood
Sep 13, 2015 05:56 PM
