Windy Noise from Righ Pasanger Window
On the freeway (at about 70mph) I can hear hiss and wind sounds from my passenger window. I was wondering if anyone has had this problem so far. I just reset the window (15 sec down/ 15 sec up) and I was wondering if that would solve the problem. Ill update tomorrow when I go back on the highway but I just wanted to know if anyone else had this problem.
I've heard a couple people complain about this and say it was a new windshield that hadn't properly sealed...if you're sure its from the window then I would just try to rest it again
For resetting it all you have to do is put the window down (no time limit) then hold the button all the way up and continue holding for 3 seconds after the window is up. Everyone says 15/15 but that's not what the manual says
I also get the hiss sound. I compared my G to my dad's and his window seems to sit a bit differently at the top part of the "triangle" above where the tweeter.
My window also leaks a little in heavy rain/washing whereas his does not.
I took my infiniti in for servicing and a TSB fix on the brake system. I mentioned the wind noise from the drivers side and they adjusted it. Reduced the wind noise, but still had some, so when I had to take it back for the brake part (a week later), I mentioned it again, and they ordered me a new moulding for the window at no charge. Have to take it back in next week for them to install which is estimated at 30 mins.
RexHavoc
Oct 2, 2015 11:47 AM
si_driver
Oct 1, 2015 09:53 AM
