Help How to get off shift knob housing
Old Apr 9, 2010 | 01:06 PM
pauliewalnutzz's Avatar
pauliewalnutzz
How to get off shift **** housing
Today i was tryin to take off the shift **** housing (09 g37x coupe) and i couldnt get the thing off. I got the shift **** off but i couldnt find a way to get the silver housing off, i pulled it back till it was loose then i just couldnt pull it up. Can someone please help me, thankyou
Old Apr 9, 2010 | 02:05 PM
hispeed-lowdrag's Avatar
hispeed-lowdrag
there are the clips that come off, and then there is 1 screw in the rear (closest to the back of the car) that is holding it down to, you kind of have to get it loose and then get a screwdriver under to undo the screw
Old Apr 9, 2010 | 03:08 PM
pauliewalnutzz
I lost ya there lol. Ok i got the silver washii piece up and i can move it around a little bit but i think the cigerette lighter wire might be the problem........... now where is this screw your talking about?
Old Apr 10, 2010 | 08:23 AM
pauliewalnutzz
Guess i gotta try to figure this out again today
Old Apr 10, 2010 | 08:34 AM
STOOF's Avatar
STOOF
well im assuming youre AT since you have an X. So there shouldnt be a screw.
After you take the **** off, just stick your finger in where the bottom of the boot is and try and pull it up, it should just pop out but its gonna be hard the first time.
You can also try using a flathead screwdriver but youre most likely going to damage the washi.
Old Apr 10, 2010 | 08:40 AM
pauliewalnutzz
Thanks stoof. i wasnt sure if i should pull it up that much because i thought i might break something but ill try that today.
Old Apr 10, 2010 | 01:22 PM
pauliewalnutzz
finally got it, in order to get the shift **** housing off you gotta take the radio face off first then the shift **** hosing comes right off.
4DRZ
May 29, 2024 09:28 AM
37
Oct 17, 2020 11:12 AM
Jonesmeister11
Sep 27, 2015 08:28 PM
Sep 25, 2015 01:38 PM
r0cketm0nkey
Sep 19, 2015 11:10 PM
