How to Remove OEM Spoiler?
Old Mar 21, 2010 | 04:29 PM
yakuzapop's Avatar
yakuzapop
Hi, I need DIY removing Trunk Spoiler, Not the Chorome one. its bigger spoiler with back up Camera.
now I took trunk off, and there are Sticky 3M tape both side,
People who have took your spoiler, how did you do it?
Need help.
Thanks.
Old Mar 21, 2010 | 04:50 PM
2008G-Man's Avatar
2008G-Man
Why would you take it off? I believe there are holes. I know if you don't have the spoiler and buy the OEM one you have to drill two holes in the trunk. Not sure if it's the same in reverse.
Old Mar 21, 2010 | 04:55 PM
Weiboy718's Avatar
Weiboy718
i recently removed the oem chrome spoiler and i don't think it's any different from removing the oem spoiler.
did you remove all the clips on the underside of the trunk? after you remove the clips and carpet there should be at least 4 size 8mm nut. try removing them and see if it'll come out. if there's double sided tape you'll have to use alittle force and look around to see if there's any other nut's or screws that's holding it down.
Old Mar 21, 2010 | 05:46 PM
yakuzapop's Avatar
yakuzapop
yeah, I took all clips and nuts off. but the Chorme spoiler is a lot easier than the other oem spoiler.. I know I have to use a little force but I don't want to break or damage it. so, I wanted to know easier way to remove it.
Old Mar 21, 2010 | 07:18 PM
Haji's Avatar
Haji
If theres glue under it, a little heat gun action would help tremendously, but be careful not to fry the camera lol.
KJA8686
Mar 15, 2021 01:27 AM
pal51961
Jan 16, 2016 08:26 AM
KAHBOOM
Aug 25, 2015 11:05 AM
SpeedBallDEVIL
Aug 12, 2015 04:30 PM
RoyalG37
Aug 11, 2015 12:21 PM
